Can you mix h & hx acl race bearings
Old May 6, 2009 | 06:15 AM
namm's Avatar
Default Can you mix h & hx acl race bearings
I know when you are using OEM bearings you can but a brown and a green bearing on the same journal to get the desired clearance. Is this possible with ACL H & HX race bearings or are the difference in thicknesses too wide.
Old May 6, 2009 | 08:44 AM
champLSinteg's Avatar
Default Re: Can you mix h & hx acl race bearings
If they fit yes but you still need to make sure the clearances are in spec.
Old May 6, 2009 | 09:06 AM
mar778c's Avatar
Community Builder
Community Influencer
No. The race bearing has an addditional .001 of clearance relative to the std bearing. That would be like mixing red and blue bearings.
rwautomotive
Engine Machining & Assembly
Jul 19, 2015 08:30 AM
crashsvg
Jan 9, 2014 05:30 AM
adubaz7
Oct 3, 2007 07:49 PM
RACEPAK
24
Nov 9, 2005 11:08 AM
