B16 Boost Problem.. Help
I had basically a 6 pound spring in my 38 mm wastegate and it would spool up to 6 no problem. Well I put a boost controller on it to set it to around 9 or 10 pounds and as soon as I hit around 8-9 pounds I get bad boost cut. I have a stock map sensor and my chip is set to 11.2 pounds for boost limit on the map sensor. I also recently bought a new spring for my wastegate to eliminate the boost controller. The spring is a small blue spring which is 8.7 psi. Now it cuts everytime I boost to 8-9. I don't understand why it boost cuts there. Anybody have any ideas?
Boost cut as in soon as I hit 10 usually, the boost cuts out and it feels as if it's serious fuel cut. My friend uses Hondata s300 and there is an option for boost cut and that's what mine feels like. I think my gauge is correct because when I had the 6 psi spring in, it read 6 psi everytime before the boost controller. My AFRs are somewhere in the 11s full throttle so I don't think it's anything to do with fuel. Also have a Walboro 255 in right now.
91integraLSVTEC
Oct 21, 2009 11:09 AM
jetlude
Aug 1, 2007 09:13 AM
