My Vic wanting to die with A/C on!!!
Old May 5, 2009 | 10:37 AM
cueto's Avatar
Default My Vic wanting to die with A/C on!!!
Ok.....so here recently if im sitting at idle and I have the A/C on my 94 vic dang near dies on me!! The rpms go to about 100-200 and engine shakes like its about to die. I assume this is happening when the compressor is on but WHY? What do I need to replace?
As Always..................thanks for any comments and suggestions!!
Old May 5, 2009 | 10:42 AM
Former User's Avatar
Default Re: My Vic wanting to die with A/C on!!!
Is the A/C having problems or noisy? If not, try cleaning the IACV on the throttle body. Another possibility is a problem with the A/C wiring that tells the ECU to ramp up the idle speed when the A/C is turned ON.
Old May 5, 2009 | 11:53 AM
rick_rabies's Avatar
I'm not Rick!
check your altenator
Old May 6, 2009 | 08:02 AM
cueto's Avatar
A/C not noisy or abnormal! When driving its fine but when I stop and motor is idling it jumps down to LOW rpms and motor shakes around (i guess about to die) ! I wouldnt think that its the alternator but Ill have it checked!! Any additional help would be fantastic.
Thanks
Old May 6, 2009 | 08:04 AM
cueto's Avatar
****Is the IACV the idle control valve??? Ill chek what I can and clean.
ITR EG
Apr 12, 2008 09:29 PM
averyvm
17
Jan 17, 2007 11:51 AM
upinsmoke
Aug 20, 2005 06:57 AM
BACKintheDA
Feb 22, 2005 11:23 AM
wolf3007
Mar 26, 2004 05:06 AM
