Fuel pump delay...
Old May 5, 2009 | 09:55 AM
SurferDude905's Avatar
Default Fuel pump delay...
Installed my walbro 255 and everything has been fine for the past 2 weeks. I was out last night and parked the car, when I came back to the car and turned the ignition to prime the pump nothing happened. About 10-15 secs later the fuel pump came on....
What can this be?
Old May 5, 2009 | 10:55 AM
fcm's Avatar
fcm
Old Fart
Default Re: Fuel pump delay...
Pull and check the PGM-FI Main Relay...
http://www.tegger.com/hondafaq/mainrelay.html 94
Old May 15, 2009 | 08:14 AM
driveslow's Avatar
bump for answer as I am having the same problem. Folks on here have swapped main relays and ecu's and continue to have the same problem
Old May 15, 2009 | 02:33 PM
driveslow's Avatar
bumpage
Old May 17, 2009 | 04:27 PM
driveslow's Avatar
Well it appears that the problem is getting worse. I let the car sit for 3 days without trying to prime the fuel pump and this time it took 2 minutes. I actually talked to some honda techs, 2 different dealerships and they all told me to wait till the car stops starting to diagnose the problem. In other words. Wait until your stranded at work, call a tow truck, and have it be a total inconvenience. That is like telling a person to get a extremely before going to see a doc.
I think I will try to reset the ECU and see if that resolves the problem. If there is anyone else that has resolved this issue, please chime in.
Old May 17, 2009 | 06:30 PM
jlude90's Avatar
call walbro?
Old May 17, 2009 | 06:52 PM
driveslow's Avatar
Originally Posted by jlude90
call walbro?
oh sorry. my issue is with stock pump. bump since it is happening with stock an aftermarket. I would assume its not the pump.
Old May 17, 2009 | 08:56 PM
jlude90's Avatar
i was talking tot he OP
Old Jan 22, 2011 | 11:54 AM
fastwanabe's Avatar
pulling the ecu out and letting it reset fixed this very same issue for me.
Old Jan 22, 2011 | 03:10 PM
fcm's Avatar
fcm
Old Fart
Could be a problem with the pump, PGM-FI Main Relay or the ECU.
Do you hear the PGM-Main Relay "click" on when you turn on the ign.?
The PGM-FI Main Relay "clicks" 3 times...
First click is the fuel injector relay turning on, [controlled by the ign. switch].
The 2nd click is the fuel pump relay turning on, [controlled by the injector relay (power to coil] and the ECU/ECM [ground to coil].
The 3rd click is the fuel pump relay turning off, [ground from ECU/ECM is dropped]
Keep in mind the first and second clicks will sound like one click as they are very close together, to be sure what the problem is you will need to do some testing at the PGM-FI Main Relay.
What is MM&Y of car?94
Old May 18, 2011 | 10:46 AM
Galan's Avatar
Have you (OP) found the solution to the fuel pump not priming? Thank you
Old Mar 1, 2012 | 09:49 AM
fastwanabe's Avatar
After many months of BS with this problem replacing the Ecu was the cure.
Old Apr 1, 2017 | 09:47 PM
crouser's Avatar
Icon6 Re: Fuel pump delay...
had that problem with a 92 integra gsr the problem was the solder on pin seven of connector a in the ecu the heat caused it to loose connection via stress cracks the delay comes from current heating up the connection just put new solder on it and it now starts at the turn of a key it sat for three years so glad I got that figured out
B16afmaxt
Mar 22, 2010 06:26 AM
tempname
Sep 7, 2008 05:46 PM
jwatheyjr
Aug 12, 2005 04:13 AM
AcidFr33ze
Aug 7, 2005 10:21 AM
