Help me identify the cause of this noise (2 Videos inside)
Old May 5, 2009 | 12:10 AM
Shiznit028's Avatar
Default Help me identify the cause of this noise (2 Videos inside)
its a b16a2 with 90k miles. currently the motor is bone stock although it was boosted for about 1,000 miles. however this noise started about 20k miles since i took the turbo kit off.
it should be noted that sometimes when the motor is mildly warm, i can hear what im guessing to be a coolant line clog up, which immediately causes the noise to stop completely, and my motor sounds how it did when i bought it about 50k miles ago. within a second the "clog" passes and the noise continues as usual. again this only happens when its starting to get warm.
parked in the garage.
http://www.youtube.com/watch?v=hV9I6QghLlc
driving. on this video please pay close attention to the noise at around 35 seconds.
http://www.youtube.com/watch?v=BTCN_t-K6YU
when i described the noise i heard it was everything from rod knock to the water pump, so i thought i would post videos of the sounds. let me know what you think it is and how certain you are.
Old May 5, 2009 | 09:13 AM
medorihb's Avatar
Default Re: Help me identify the cause of this noise (2 Videos inside)
i have no clue man. hopefully someone on here can help you out. it's just hard to distinguish.
Old May 5, 2009 | 10:11 AM
honda_1's Avatar
hey does your car feel any different like its bogs down or lots of vibrates while idles?
Old May 6, 2009 | 03:32 PM
Shiznit028's Avatar
nope, car feels normal other than that aweful noise
Old May 6, 2009 | 03:39 PM
civic_driver's Avatar
In the first video it kiind of sounds like there's no oil to lubricate the bottom end. Or maybe the top end needs to be adjusted. Can't really tell where it's coming from, from the video.
Old May 6, 2009 | 03:54 PM
TravisCadello's Avatar
Sounds nasty. I think its a bad timing belt tensioner. maybe the timing belt tensioner has bad bearings and it causing it. This is probably the problem check it.
Old May 6, 2009 | 03:59 PM
R666_EK's Avatar
Hard to tell from the video. Could be the crank pulley/harmonic balancer. Worth a look.
When you rev it does the noise get louder? Does it increase speed with RPMs?
Old May 6, 2009 | 04:03 PM
it sounds like bad bearings somewhere. not a motor problem though. not rods bearings or any crazy **** like that. the crank pulley don't have bearings R666 EK. And it sounds like its coming from the timing belt area. and you have a lot of miles. right around the miles the timing belt and water pump and tensioner needs replacement.
Old May 6, 2009 | 05:10 PM
R666_EK's Avatar
I never said it had a bearing.
It could be anything. I simply told him to take a look. At idle its not a constant noise.
Old May 6, 2009 | 05:13 PM
I know you didn't just letting the OP know. It couldn't be that crank pulley. Its best that he finds out WHERE the noise is coming from and go from their. I hear it from the timing belt area on the videos he posted. im not sure though.
Old May 6, 2009 | 07:08 PM
honda_1's Avatar
i think it might be the idle pully or timing belt tensioner idk? some kind of bearing is busted lol
Old May 6, 2009 | 07:11 PM
sp00ledbseries's Avatar
I would start with the crank pulley. Then take the timing belt cover off and inspect.
Old May 6, 2009 | 07:36 PM
Shiznit028's Avatar
i checked the oil levels, they are right where they should be. oil still looks brand new although it was changed about 1500 miles ago. the noise is coming from the belt area, im not sure which belt though.
tensioner has never been touched, but ill take a look at it as soon as finals are over.
yes it gets louder with engine speed
thanks for that info. ill take a look at the tensioner first chance i get.
it actually is a constant noise, it just is quieter at idle.
ya the noise is definetely coming from the timing belt area.
ill add that my car, when its at idle, sounds like its a 1.6 liter V8 that is idling.
Old May 6, 2009 | 07:55 PM
lol, i wouldn't drive it much man. well unless you want that tensioner to let go of the timing belt and bend a few valves and ruin the head.
Old May 7, 2009 | 12:45 PM
Shiznit028's Avatar
well i found out what it was. i took the lower timing belt cover off and started the car so i could see where the sound was coming from better. it turned out to be the power steering pump. luckily i had an extra steering column in my garage, and replaced the pump real quick.
thanks for the help everyone
RobFarns
Oct 22, 2010 05:52 PM
kcari
Suspension & Brakes
Oct 28, 2009 12:30 PM
24boosted
Honda Civic (2006 - 2015)
Mar 17, 2007 06:09 PM
...rohit
May 5, 2006 08:15 AM
