Help with Integra GSR Axle
I notice that my driver side Axle boot is ripped and I notice that the axle is 2 piece my question is Do i need to replace those 2 pieces or just the piece that from the wheel to the part from where it splits to the other part of the axle that conect to the tranny
Im puzzled cause i never sawl this on civics
Go to autozone or advanced or any local parts store and pick up the manual for your specific year/gen integra.. money well spent IMHO.
Did you try searching? There are write-up's for this..
https://honda-tech.com/zerothread?id=382416
https://honda-tech.com/forums/acura-integra-type-r-8/axle-replacement-458973/
the part from the tranny to the axle is called the intermediate shaft. its bolted on to the chasis with 3 bolts and doesnt move. it just rotates. it has a shaft like the axle does and its like a ***** cause the axle on the driverside is called a female axle. it has like a vagina. the ***** from the intermediate shaft goes into the vagina on the driver side axle with then extends threw your hub. be careful if taking the intermediate shaft out do not pry on the metal part that meets the tranny. tho u dont need to take it out at all just use ur prybar after the bushing and between the axle
do not buy ur axle at the dealer theyll rape u in cost.. autozone has lifetime warranty on axles but their **** but like 100$ish also u give them ur old axle for core cost and they rebuild it and resell it. thats all autozone axles r, r rebuilds.
choose wislesy in your quest sir
MikeTV
Jan 4, 2005 06:17 PM
