GSR swap.. Sensor idetification..?
Old May 4, 2009 | 03:10 PM
lvlrkmart's Avatar
Default GSR swap.. Sensor idetification..?
Their a connection/sensor plug on the back of the block. Its a 1 pin clip, below the intake manifold but above the fuel filter... any idea what it is?
also the sensor directly next to the oil filter...? is that the knock sensor..?
thanks for any help..
this is a b18c1.
Old May 5, 2009 | 06:39 PM
LOVEthatDC2's Avatar
Default Re: GSR swap.. Sensor idetification..?
are you going obd1 to obd2? I will be doing the same thing very soon. I'm curious as well ...
Old May 5, 2009 | 07:04 PM
bluxberryxhaze's Avatar
if your swapping the gsr motor.
you need to run vtec/knock sensor which is under the IM, and secondary runners if you are planning on keeping the stock IM.
Old May 5, 2009 | 07:18 PM
boostdc211's Avatar
sensor directly next to the oil filter is oil pressure sensor
Old May 6, 2009 | 01:06 PM
what are those supposed to be run to? thanks!
Old May 9, 2009 | 02:55 PM
negusjuda's Avatar
not to jack this thread but im also doing the same swap in a 91 integra ls and i plan on going obd1 my question is since all i got with my motor was the block full internals and the head full internals but i dont have the alt, start, a/c compressor, power steering and al lthe other external stuff my question is can i reuse all my ls parts on the gsr and also do i use my ls wiring harness since i dont have the gsr harness i know i have to get a jumper harness for obd1 and i know i have to run wires for the vtec and knock sensor but does everything else convert over like my other sensors from my ls and things like the altenator and ac and power steering
EnviedByMany
Feb 23, 2011 08:54 PM
EK FLY
Nov 12, 2006 10:20 AM
endlesswinterco
Jan 3, 2004 10:41 AM
flat-blk-HB
10
Sep 28, 2002 08:22 PM
infamousALLMTR
Apr 15, 2002 02:36 PM
