Few electrical issues with my 97 integra
I have a gs integra and i have 3 problems
1. my turn signals wont come one on the cluster not even the 4 ways nothing is it the relay
2. my srs light is on
3. my abs light is on
i heard once that the relay for your hazards also allows your turn signals to work and that if it goes out you will not have turn signals nor indicators in the cluster. so check that relay, the abs light- well there is a method for pulling the code, fix the problem, abs light goes off. srs- thats airbags, not sure why that is indicated, has the car been wrecked before.
do the turn signal lights flash?
1 thing also if your hazard switch is not connected your lights may also not work because of that!
SRS light, Do you were your seatbelt?
like guy above me said, has the car been in a accident?
ABS light- have you check your brake fluid? do you need brakes? if your car needs brakes then the brake fluid level goes a lil bit low and will cause the abs to turn on!
srs car hasnt been in a car accident i know it for a while before i bought it
abs i think the previous owner messed with the muffler and it burned out that abs wire on the passenger side
and my turn signals dont flash on the cluster either i dont know how to pull out that 4 way switch to check i dont want to break it or the climate control I will have to see if i can find the hazard relay..
oG BIN
Nov 7, 2006 08:58 AM
hondaracin24
Feb 27, 2006 12:16 PM
