Broken ect sending unit sensor.
Old May 4, 2009 | 10:46 AM
c0d0r's Avatar
Default Broken ect sending unit sensor.
That's right, it's in an obd1 b16a.
It's not the two wire ect sensor that reports to the computer, it's the single wire one for the temp sending unit on the cluster.
I was trying to remove it from the head while the engine was warm like a dumbass and the sensor broke in half leaving the other half of the sensor (threaded part) flush in the head.
Anyone have any idea on how to remove this?
The sensor itself is hollow with a plastic sheath around a spring, both of which have been removed so that can give me some help...
Old May 5, 2009 | 06:44 AM
c0d0r's Avatar
Default Re: Broken ect sending unit sensor.
bump
Old May 5, 2009 | 07:01 AM
Former User's Avatar
You might want to try using a reverse threaded extractor tool like the one shown in the picture. This tool can be purchased from your local hardware store.
Old May 5, 2009 | 07:20 AM
shoklid's Avatar
this is off the topic. i have code 86 ect cel light on. changed the temp sensor and light came back on. what sensor is the ect sending unti like as its location relevant to temp. sensor. btw i have a b18c if it makes any diff. its obd2b
Old May 5, 2009 | 07:33 AM
Both are located under the distributor. Only the 2-wire sensor will throw a code, not the 1-wire sending unit.
Old May 5, 2009 | 08:27 AM
shoklid's Avatar
**** i replaced it and the light came on 40 miles later. any thoughts as to why
Old May 5, 2009 | 01:07 PM
c0d0r's Avatar
check the resistance of the new sensor at cold and hot to make sure it's sending correct signals back to the pcm. I believe it uses a 5 volt reference wire and a return wire to the computer...grab a service manual for procedure, I believe all b series are the same.
knboard
Honda CR-V & Element
May 12, 2018 10:19 PM
710dabber
Nov 5, 2015 12:36 PM
syphonp2
Sep 23, 2009 07:17 PM
99d-series
May 1, 2009 08:56 AM
