S4C into an EF with OBD1?
Old May 4, 2009 | 09:53 AM
SolAssassin's Avatar
Default S4C into an EF with OBD1?
I'm having some trouble with my B swap. Recently I bought a 00 Civic Si S4C transmission, and like an idiot I sold my cable tranny with the speed sensor in it. I plan on going OBD1 with a jumper harness to the ECU. My question is, do I need to source another cable speed sensor and replace the electronic one in the S4C? If I am going OBD1, how is my ECU going to be able to determine my speed and RPMs with a cable speed sensor? Lastly, can I keep my TD-22U OBD0 B16 distributor?
Old May 5, 2009 | 11:08 AM
Default Re: S4C into an EF with OBD1?
nobody knows anything about this huh?
Old May 5, 2009 | 06:16 PM
88Hatchy's Avatar
If the S4C has the electronic VSS then you could convert to a different cluster. If it doesn't have the VSS, then use one from a D series manual tranny.
Oh, and you will need a OBD1 Distributor
Old May 7, 2009 | 06:07 AM
ok... then my question is why do i need an obd1 distributor? what makes it different internally?
Old May 7, 2009 | 06:40 AM
per4mance's Avatar
get another cable vss. The car already has the wiring from the gauge cluster to the ecu for the cable vss. You need the obd1dist because the pick ups are different between that and the obd0 dist. Just use your factory engine harness plug it all up like a normal obdo motor. Add your wires for vtec, knock, 4 wire 02, etc. Plug your adapter harness in and thats it. Also you will need to either repin the obd0 dist plugs to obd1 or by a dist adapter harness to convert. I believe rywire has one.
Old May 7, 2009 | 10:00 AM
thanks for the info
Yodi71
Feb 11, 2019 12:21 PM
94 ls-r
Jan 25, 2011 06:45 PM
jdmek9imagex
Sep 5, 2008 06:14 PM
darknessgsr00
Sep 16, 2005 05:42 AM
04falcon
Nov 26, 2004 08:47 PM
