Transmission took a crap? any ideas?
ok so last night I was driving home on the highway, came to the toll road, came to a stop.. then when i started accelerating again and went to 1-2 shift it wouldnt really go into gear, and it feels like the cluch is halfway engaged.. i can sort of get the car moving in the 1-2k RPM range but when i try to put it in any gear its like extremely hard to do so. if the car is off it moves into all gears smoothly. Any ideas for me guys? I was wondering if its just the clutch took a crap.
yes check what he said. and if thats not leaking..check ur slave...if none of those then maybe ur clutch is ****ed up thats what happen to mines the spring jumped out and sat in between the pressure plate and clutch...
similar thing happened to me, check what they said above and if that's not it just hope its only the clutch. mine turned out to be missing a chunk of the clutch causing it to not go into gear correctly. good luck!
F-1 clutches are great! theres a few threads on it here if you dont have experience dont give false advise there great! im still using my stg 3 on my jrsc'd gsr!
had this problem on my boss's lued, took tranny out clutch disk springs had broke out and clutch disk center " non friction" surface was preety damanged.
As for those F-1 clutches iv been doing alot of reading up on them cuz I have a build starting preety soon and they seem like a preety good buy, although some do have some problems it's mostly the guys that have never owned one that have the most negative things to say about em.
Is it hydro or cable your tranny? Does it grind or chatter when try to engage? Next if hydro could be a bad slave cylinder or clutch master cylinder, because you said it stays half ways...If cable check your tranny cable and adjust as need by turn on the black **** by the tranny...If nothing still or pedal falls all the way then it could be a bad clutch.
sniper_king
Aug 2, 2013 10:37 PM
no..
