vtec wont work
Old May 4, 2009 | 04:27 AM
westmidscivic's Avatar
Default vtec wont work
i got a problem with my poor civic, i was drivin home from work yesterday and booted the car wen she was all warmed up but the vtec wouldnt work, its a b16a in a uk esi d series shell, the car was working fine and now this has happened and it just wont engage the vtec, ive cahnged the vtec solinoid nd checked all the fuses nd sensors but still carnt work it out, im so confused can any1 help me please
Old May 4, 2009 | 05:11 AM
monkey_boi's Avatar
Default Re: vtec wont work
what about your ecu ???? is it chipped ???
if so then try reflashing it sometimes it can get lost very rare but it can happen
also you may want to check engine codes that it may through at you
21 VTEC spool solenoid valve
22 VTEC pressure valve
Old May 4, 2009 | 05:32 AM
no the ecu i got arnt chipped, ive tryed swapping my p28 for a p30 as they both work but the car is still not engaging the vtec, im gona try the code job now just 2 see if anything flashes up, how do i reflash the ecu like u sais pal u lost me there
Old May 4, 2009 | 05:38 AM
no flash codes come up on the car it just stays on so i think the sensors are all ok im stuck now
Old May 4, 2009 | 05:46 AM
monkey_boi's Avatar
ok i have no idea really........
oh wait try to take out the battery and let it sit for a bit then reconnect it basically reboots try that....
Old May 4, 2009 | 07:21 AM
shoklid's Avatar
i have the same issue and lost myself. but i have code 86 and changed the temp sensor cel went out and stillno vtec
Old May 4, 2009 | 07:27 AM
heritage36's Avatar
Dang, if I lost my VTEC my car would not be too fun to drive anymore, I would be working in a panic to get that fixed!!!
Old May 4, 2009 | 09:01 AM
medorihb's Avatar
sometime the filter on the vtec solenoid gets clogged. if this happens vtec won't engage because the oil psi isn't what it needs to be. remove solenoid and clean filter. and check oil level.
Old May 4, 2009 | 09:36 AM
big_tiger's Avatar
Icon6 Re: vtec wont work
What do I check if it is code 21
<<<noob that can't start his own thread
redegboosted1's Avatar
check your oil. vtech runs off of oil pressure. not enough oil no vtech. trust me i had vtech problems just the other day and i almost blew my engine with no oil and that was my problem. lmk
Old May 4, 2009 | 09:39 AM
FearTheH's Avatar
to start a new thread, just go into the main forum and above the threads theres an icon that says "New Topic" then enter title, and so forth.
Old May 4, 2009 | 09:54 AM
Wow! Someone can explain how to start a new thread. Thats Am-A-Zing! WOW I'm in shock
Old May 4, 2009 | 10:08 AM
FearTheH's Avatar
you're a smart *** and a douche bag, he said hes a noob and doesnt know how to start a new thread. no one else was going to tell him, you're still a noob too, if you cant say something to help someone in a TECH forum, GTFO and if youre unsure what that means maybe you should ask someone and get flamed for it.
Old May 4, 2009 | 10:26 AM
monkey_boi's Avatar
there is a lot that can be checked frst if it does a code 21 then check the vtec sely
and the wires to the firewall and check the sensor connected to the sel
if that seems to be ok then check the ecu and make sure that you have the pin a14
oh and make sure that the wire is not melted or anything.
if everything seems fine then i am sorry but your fooked mang you just may need a whole new harness or you can just run with out vtec !!!
Old May 4, 2009 | 10:29 AM
Windizzle's Avatar
THis!
Old May 4, 2009 | 11:38 AM
big_tiger's Avatar
I read the warngng thing wrong. I can post here just not in the marketplace and appearence sections.
big_tiger, welcome to Honda-Tech! We hope you enjoy the site. Please note that during your trial period you will not be able to start threads in either the appearance sections or the marketplace sections of the site.
As soon as you accrued 5 posts and have been a member for 15days, you will be granted this ability. If you see this notice and you have exceded the 5 post and 15 day prerequisite, please wait up to 1 hour for the software to grant you this ability.
I am not new car forum boards.
Old May 4, 2009 | 11:40 AM
big_tiger's Avatar
My car is a 95 CX with a rywire harness' (plus O2). What sucks is I get a code for both the Vtec and O2. Which is everything I installed, lol.
Old May 4, 2009 | 11:48 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
check the wiring to your knock sensor...make sure everything is wired correctly...
im in the process of diagnosing this same kind of problem. I tried running stock ECU's for my B16 and it ran but no VTEC...i tried a stock JDM ITR (P73 i believe) and a stock GSR ECU. Neither one worked. But as soon as i plugged in a chipped P28....whallah....all is well...
Old May 4, 2009 | 11:49 AM
the reason the P28 is engaging "VTECH" ( lol ) as someone stated before, is because the P28 is not looking for a knock sensor...the other ones are...the knock sensor could either be faulty or not wired correctly...
dougk1401
Dec 7, 2009 08:55 AM
agiorlando
28
May 14, 2007 06:08 PM
Andres-eh2
May 18, 2006 12:10 PM
686_ef
12
Feb 13, 2006 08:31 PM
AZMRSi
Aug 30, 2003 11:43 AM
