need help with my motor
Old May 3, 2009 | 08:39 PM
b20steveo's Avatar
Default need help with my motor
i have a gsr block and a b16 head what head gasket should i use and what timing belt
Old May 3, 2009 | 08:51 PM
iwanttokillgod's Avatar
Default Re: need help with my motor
dohc vtec head gasket have used both gsr and b16 head gasket had no problems with either , as far as the timing belt it depends on what water pump your using if 22t water pump gsr/type r timing belt , if you using the ls water pump ls timing belt but more then likely your gsr bottom has a 22t water pump
honda_ek9
Dec 2, 2010 09:16 AM
TooManyTickets
14
May 27, 2007 03:05 PM
B6tizzleHatch
14
Aug 14, 2006 08:49 PM
Turbo R
Feb 12, 2006 10:14 PM
11secEk
Feb 7, 2005 03:01 PM
