my engine went boom
Old May 3, 2009 | 07:03 PM
layedoutat0psi's Avatar
Icon3 my engine went boom
ok lets keep this simple. AND I DID SEARCH AND DIDNT FIND ANYTHING. i dont kno if i just didnt look good enough or was to damn impatiant to keep searching. i have a 96 civic with a y8. after 185,000 miles of being beat on it finally blew up. sent a rod through the side of the block. ok so anyways. i have been givin a 1.5 out a an eg for pretty much nothing. good strong runnin engine. plans are are to put my y8 head on the 1.5 block. but i have two questions to do this. which timing belt and which head gasket do i need to do the swap? any other things you wanna throw in there will help out to. thanks any help will be appreciated. especially since plans were to drive my car 4 hours this weekend (5 days from now, 8 hours total) to a huge car show! please no smaart *** remarks. like i said i ddi search and still are kinda aggravated from my car blowin up.
Old May 3, 2009 | 07:10 PM
95civhb's Avatar
Default Re: my engine went boom
https://honda-tech.com/forums/hybrid-engine-swaps-18/d16y7-y8-mini-me-questions-did-search-326048/
that should help you out..
Old May 3, 2009 | 07:14 PM
sweet thanks dude. so if i read it right i need the timeing belt and head gasket off the y8?
Old May 3, 2009 | 08:39 PM
oh and what head bolts do i use
Old May 3, 2009 | 08:58 PM
Davus's Avatar
You'll likely want to get some ARP bolts, and may have to contact the company to mix/match if you need different types. I know with Z6/Y8 combo you need 9 from one block/head, the other from the other type. I'll see if I can find specifics.
Also, sup thrown rod buddy? http://tinypic.com/view.php?pic=35iyf68&s=5
Old May 3, 2009 | 09:00 PM
TravisCadello's Avatar
I'm running the exact same set up now. the D15 block and Y8 Head.
You need to use i think it is 9 head bolts from a d15b7 head and only 1 of your d16y8 head bolts the one where the y8 head bolt goes is right by the V tec Solynoid.
Also, Run the y8 head gasket and y8 timing belt. Good Luck and i hope you have it finished in 8 days. work ur *** off. any questions PM me. I just Did mine.
Old May 3, 2009 | 09:07 PM
en00be's Avatar
D series....sigh
Old May 4, 2009 | 07:19 AM
now i also heard about having to pull a pin out of the head or block or somethin to run this setup?
Old Aug 10, 2009 | 04:12 PM
honda1234567's Avatar
I am also running exact the same thing.
$29 auto insurance for any honda civic and must be between ages 16-29.
@ http://www.inexpensive-auto-insurance.com/
Old Aug 10, 2009 | 04:21 PM
:::SIRll_EJ1:::'s Avatar
i think its one of the dowel pins that need to be removed in order for the head gasket to fit... im not sure tho.
Old Aug 10, 2009 | 04:24 PM
92lxsleeper's Avatar
http://hondamarketplace.com/showthread.php?t=2619785
$800 you can have my car, and swap everything out into your car.
sd619jef9
Apr 6, 2012 09:24 PM
myflyintegra
Jan 14, 2009 06:48 AM
THC07
Oct 26, 2005 10:57 PM
loclowd
May 6, 2003 08:07 PM
