Help D15B block Y8 head.
ok so ive looked all over archives and found no info.
I have asked a few times and no one can give me a good answer.
I have a D15B block, i want to use the Y8 head, what are the precautions.
which gasket
Which distrubutor
which cam
which ECU p28 or p08
1 or 4 wire o2 sensor
which timing belt
And is there somthing im missing. my D15B head is shot so i have to switch and i have to do it right the first time. only have one day. Please give helpful info, this will help a lot of people doing simalir things.
which gasket
Which distrubutor
which cam
which timing belt
Re: Help D15B block Y8 head. (THC1107)
did search very heard huh.... heres all the info you should need. gaskets and all
https://honda-tech.com/zerothread?id=554053
and use the whole head. not just parts form another one!
Re: Help D15B block Y8 head. (xCIVICx)
almost, his story is a little different, his block has a knock sensor, mine is in the dissy. he is talking about z6 and y7 i don't think they r the same
no there different, do some searching on the 2 unless your doing the y8 cause you already have it, but one difference is that the y8 is obd2 and the z6 is obd1, your block is also obd1, so with the y8 you have to decide which way you wanna go
Re: Help D15B block Y8 head. (Civicse)
im goning to use the Y8 head, all i have to do is get a p08 or p28 ecu to be obd1 right, do you know which o2 sensor you should use for p28 or p08?
