blowen headgasket I think
Old May 3, 2009 | 01:28 PM
CivSiClone_96's Avatar
Default blowen headgasket I think
hey got a built b20b with a gsr head I just got done finishing up my build, driving home it started to overheat really bad ended up having to tow it back to my house . The next morning I went out popped the radiator cap off there was coolant in it so I started the car with the cap off let it warm up to the right tempature and noticed there was a white milky substance whice would be from oil mixing with the coolant which is a blowen headgasket correct???. Just wanting to know what ppls think before I pull the head. Thanks for ur time.
Old May 3, 2009 | 03:59 PM
Nick97hatch's Avatar
Default Re: blowen headgasket I think
Soundslike you are on the right track. What head gasket did you use? Did you use new head bolts and was it torqued properly?
* Never seen someone on HT so close to me... I live in wilsonville *
Old May 3, 2009 | 04:50 PM
I used a cosmetic 85mm gasket im using 8mm ARP headstuds and was torqued to 90lbs. I pulled the head and to find out i forgot to put the molly lube on the headstuds which I believe would cause the gasket not to seal correctly ...the glorey of working on cars..always keep it lubed .
Old May 3, 2009 | 05:10 PM
SquirtleSquadEf9's Avatar
well im guessing u figured it out already. but the way to know for sure is let the car run for 15 mins take the oil filer cap off. if its milky than u have a blown gasket
Old May 3, 2009 | 05:17 PM
newtype_33's Avatar
yeap...but dont forget to used molly lube when you installing the arp`s
Old May 3, 2009 | 07:42 PM
wunfstgsr's Avatar
Loved
Community Favorite
apply it on both sides of the washer and a little in the nut! use a new gasket and your golden.
Old May 3, 2009 | 07:49 PM
h2.4's Avatar
Make sure you use a precision straightedge to check the head and block before your reassy.
Old May 3, 2009 | 07:59 PM
ya I will im getting the head re-decked, then gotta get some molly lube a gasket lube those ARP's up and BAM poppin VTAK AGAIN!!! .
Old May 3, 2009 | 09:36 PM
munoz4415's Avatar
u figured it out yourself
Ehron
22
Apr 1, 2022 07:01 AM
AddiXz
Nov 3, 2013 06:02 AM
efjones9
May 1, 2009 06:48 PM
bigdaddyvtec
Jun 12, 2006 07:03 AM
JTCdudeman
Sep 29, 2005 05:42 AM
