****car vibrates**
Alright guys need some help i have a 95 integra ls with a b20b swap, now i changed both of the axles and even the rotors and pads the only thing left to change i now is my rear motor mount wich is messed up including the tranny side torque mount, now the only thing is the car only vibrates when i accelarate so was wondering can the rear mount and torque mount affect the car in the way??? pls help im scrathing my head on this one.
Start with the rear mount, you said it's messed up so it needs to be replaced. I don't recommend "throwing parts at it" but that mount needs to be replaced anyway.
Did you use new or rebuilt axles? Bad axles can cause horrible vibrations. Rebuilt axles can be hit or miss.
im gonna change the rear mount this weekend but yeah the axles are new and the old ones were busted, alingments fine no jerking in either direction and dosent affect steering at all just vibrates at acellaration.
brand new but from az, and what ive heard is that i have to get the factory ones because 1 az axles suck in the first place and 2 their a little shorter than the oem ones is that true? and can this be causing the vibration?
Civicfanatic_09
Oct 6, 2009 02:45 PM
