bad coolant hose.
Old May 2, 2009 | 09:13 AM
soclean1k_JDM's Avatar
Default bad coolant hose.
So yesterday at the bank the smell of burning coolant came back to haunt me. checked my coolant and it below the low level. it started leaking out. when i got home driving slow and careful watching my temp i got home opened the hood and it was squirting out of the hose that loops from the back of the head to the back side of the intake manifold. So now im going to replace the hose and bleed the system. How do i bleed the system? Anyone ever have this hose go bad? Oh the engine is a JDM D15B
Old May 2, 2009 | 09:27 AM
Former User's Avatar
Default Re: bad coolant hose.
Turn the heater ****/lever on the dash to max heat and then follow these directions:
Old May 2, 2009 | 05:42 PM
sde780's Avatar
^ where is this bleed bolt located? where the upper rad hose connects to the engine?
Reason I ask is, I've always bled it by filling up the radiator, letting it idle for 15 minutes, then putting the cap back on
Old May 2, 2009 | 05:57 PM
5th gen but not 6th gen Civics have a bleeder bolt. Actually, I am not sure whether JDM engines have a bleeder bolt.
The bleeder bolt is located where the upper radiator hose connects to the engine:
Old May 2, 2009 | 06:15 PM
sde780's Avatar
Cool stuff. I'm pretty sure I don't have one on my 4th gen civic
Old May 2, 2009 | 06:27 PM
Actually 4th gen Civics also have a bleeder bolt:
Old May 2, 2009 | 09:49 PM
i can use this same method even replacing my thermostat im gonna do that also.
Old May 3, 2009 | 07:30 PM
clean92ex's Avatar
When you bleed the system make sure you have the heater and the fan both turned on and all the way up. Otherwise you're not getting the coolant that's back in the heater. I'd run water through the system and wait until that's all that's coming out before you put coolant back into it. If you don't run it with the heat on you run a risk of getting it airlocked, and having hot coolant sprayed into your face isn't fun. Trust me...
Old May 4, 2009 | 09:24 PM
so i broke the bleeder bolt..haha.
ordered a new one it comes wednesday
Old May 4, 2009 | 09:31 PM
JarvisW's Avatar
Sol to Sol
Oh, and bleeding on an incline (front up) helps a lot too.
Doesn't have to be ramps, but a sloping driveway, or whatever would be good.
lilshady6796
Jan 15, 2009 11:02 PM
sdinteg
Sep 17, 2007 06:31 AM
LStegvtec
Nov 19, 2005 01:42 PM
Paprika
Dec 21, 2004 04:51 AM
