I think I installed my Shox The wrong way....lol
Old May 1, 2009 | 09:49 PM
TravisCadello's Avatar
Default I think I installed my Shox The wrong way....lol
Yep, Well First question is when a shox goes out does it just relie on the spring? because that what the front shox did the car looked like it was hitting switch's just bouncing up and down over and over so i put new shox on it and its perfect now, but my old shox i could grab the shiny piece and push it into the shox and out of really easy and it was like a pole going in and out and didn't do nothing. my new shox i could barely move and they made a gas sound. what happen to my OEM shox?
Second Question- Ok, I'm asking if i installed the shox the wrong way because if i turn my wheel all the way left or all the way right the stering wheel gets hard and when i look under the car it is forcing the brake line into the shox and causing my brake pedal to drop to the floor untill i pump it. so if i turn to sharp now the brakes go to the floor and after pumping them twice they come back.
Soooo, Does anyone have a picture of how it should be installed?
Its a 1992 Civic Lx Sedan.
THANKS!
Old May 1, 2009 | 09:51 PM
forcefedferio's Avatar
Default Re: I think I installed my Shox The wrong way....lol
THANKS!
turn the shock forks around. they are backwards. i can't read your entire post in one sitting without wanting to paint my wall with my brains. i'll try again in a couple minutes.
Old May 1, 2009 | 09:53 PM
JarvisW's Avatar
Sol to Sol
Forced, U owe me an new LCD!!
AND the beer I just took a drink from!
Old May 1, 2009 | 09:54 PM
ok i send monies to your paypal account ready GO!
Old May 1, 2009 | 09:56 PM
JarvisW's Avatar
Sol to Sol
Heh. well, its not REALLY an LCD, I was just wanting to upgrade.
Travis, um, Brakes have nothing to do with shocks, unless when you installed them, you nicked a brake line.
JShull's Avatar
Jesus christ it's shocks not "shox".
Your OEM ones blew out, it happens when they get old. As for the brake lines, is there anyway you can put a picture up? Sounds like you have them routed wrong for sure.
Old May 1, 2009 | 09:59 PM
No, I can't get a pic up sorry. But I think they are backwards lol. and it is in the way of the calipers brake line. only when i turn my wheel all the way its in the way.
Old May 1, 2009 | 10:02 PM
left foot goes in left shoe, right foot goes in right shoe. next we will work on tying them.
Old May 1, 2009 | 10:05 PM
^^^WTF^^^
How about a picture of a shock on an EG?
Old May 1, 2009 | 10:06 PM
I'm looking everywhere and can't find a pic.
Old May 1, 2009 | 10:42 PM
Ok, This is pissing me the hell off! I know i seen a pic a few days ago of someones shocks installed on their EG and I been searching for anyones for 2 hours and my eyes hurt!!! SOMEONE Plzzzzz find a pic of a installed shock and spring on a 92-00 civic!!!!!
Old May 1, 2009 | 10:45 PM
JarvisW's Avatar
Sol to Sol
Um, Google?
Old May 1, 2009 | 10:48 PM
I am! And not **** is coming up. yes i see **** loads of pics of shocks OFF the car, But i need a pic of them INSTALLED on the vehicle!
Old May 1, 2009 | 10:49 PM
JarvisW's Avatar
Sol to Sol
You may have to look for pics of other work being done. Like Axles, or brakes or something.
Old May 1, 2009 | 10:53 PM
JarvisW's Avatar
Sol to Sol
Also, you could try to flip it in place, and if that didn't work, put it on the other side, and see whats up. If that dont work, flip it.
There aren't that many possibility. The correct one should be obvious.
Old May 1, 2009 | 10:54 PM
^^^ Thanks Bro, I serched changing axles and guess i got lucky.
http://www.raxles.com/CMFiles/Images...e-nut-copy.jpg
http://i.ehow.com/images/GlobalPhoto...Axle2_Full.jpg
But it seems i installed them the right way. what would cause this problem then!
Old May 1, 2009 | 11:04 PM
Are both Shocks the same? or is one for the Left Side and one is For The Right Side Only?
Old May 1, 2009 | 11:07 PM
JarvisW's Avatar
Sol to Sol
Likely. I was going on what you had said about not knowing. lol.
Old May 1, 2009 | 11:28 PM
fastrxu's Avatar
the 2 hours you spent searching you could have gotten a little dirty gone hands on.
right now you'd be driving your car and laughing at the no longer existing problem
Old May 1, 2009 | 11:33 PM
JarvisW's Avatar
Sol to Sol
Well, that was kinda my point.
Old May 2, 2009 | 01:29 AM
rushinplaya's Avatar
what has the world come to? people cant change their flippin shock and spend hours looking for a pic on how to do it? LMFAO
Old May 2, 2009 | 06:08 AM
Pothole987's Avatar
shocks are interchangable and it doesn't matter if its on the right side of the left side. its the forks that matter.
Speaking of forks. i need to eat. get some new shox's because if you can't figure out this simple tasks you'll need some sort of transportation.
Old May 2, 2009 | 06:12 AM
92ehatch's Avatar
sounds like you got your brakes lines routed wrong, or the forks backwards.
if you are turning the wheel and the lines are pinching/causing the pedal to drop THEN STOP ROTATING THE WHEEL!!!!
take the forks off, make sure they are the right way, and re route the brake lines the correct way
Old May 2, 2009 | 08:39 AM
B18C5-EH2's Avatar
Former Moderator
Loved
On the 1992-1995 civic the front shocks ARE DIFFERENT so you're the moron here trying to make fun of someone, yet you have NO clue what you're talking about. Shut up, and go away.
The front shocks on the 92-95 Civic are side dependant because the brake hose brackets are side dependant.
You fail at trying to be a know-it-all smart ***, dumbass.
Here's a pic of how the front shock forks should go - the front of the vehicle is to the right in this pic, and nevermind that the lower fork isn't over the lower control arm, because i was replacing a CV axle.
Old May 2, 2009 | 08:40 AM
The Brake lines are routed the right way its right their where the bolt hold the brake line on it is being forced into the shock tower the lower shock. and everything is put on the right way.
