Any way to make my F22 Civic vibrate less?
Old May 1, 2009 | 05:58 AM
rexload's Avatar
Default Any way to make my F22 Civic vibrate less?
My setup:
-EJ2 Civic
-F22A engine/transaxle
-Generic h22 mounts (ebay)
-I cut off the automatic transmission mount bracket, and welded a manual bracket
-Filled the ebay mounts with 80A urethane
My idle is 950rpm and at idle it is fine, but when I am driving it is VERY noisy inside.
I took off the engine mounts and did some grinding making sure the mounts do not touch the mount brackets.... but it made very little difference... still very noisy inside when I am driving.
Does anybody else have this problem? And is there anything I can do to reduce the noise?
I've thought about either drilling out the 80A urethane out of my mounts and filling them with something slightly softer (window-weld?) but I am not sure if this will make a difference. I also thought about saving up for Hasport mounts but I also don't have any idea if they will vibrate less.
Old May 1, 2009 | 12:10 PM
kp's Avatar
kp
Default Re: Any way to make my F22 Civic vibrate less?
I'll put my money on the mounts. They're way too rigid.
Old May 2, 2009 | 02:37 PM
rexload's Avatar
yea, it's the mounts, but what can I do to make it a little less noisy?
should i save up for the hasport mounts? or should i just fill these mounts with something softer than 80A?....or will it vibrate like crazy no matter what I do?
Old May 4, 2009 | 09:15 AM
kp's Avatar
kp
You'll have to do something drastic either way. I don't think it'd be smart to tear them up and re-fill them with a softer urethane. You may need to replace them with new/used ones a bit softer.
Old May 4, 2009 | 11:41 AM
hondaZvic's Avatar
if your positive its the mounts, then save for some good quality mounts with the street urethane. its like 60a or 65a depending on which brand u go with..
stiff mounts = vibration. not noise so much...
2 very different things..
Old May 6, 2009 | 06:22 PM
rexload's Avatar
yea you are right. i also thought about getting a new set of generic mounts and just leaving the rubber that they come with (it is pretty soft)
well i don't really know what else could cause so much noise besides the mounts? my exhaust is pretty quiet, i have full interior but i did get rid of the sound deadening tar.
there is definitely both: vibration AND noise (LOTS)
Old May 7, 2009 | 06:04 AM
hondaZvic's Avatar
is it a constant noise? or only at idle? during acceleration or just cruising down the highway?
what about the vibration? is it the same as the noise? at idle acceleration or cruising??
Old May 7, 2009 | 12:32 PM
djnikko's Avatar
You could get a urethane or rubber suspension bushing and slice it (like you would if chopping a carrot or cucumber) and basically end up with loadsa rubber/urethane washers. Then just place them inbetween every mating surface on the mounts. Of course it would mean removing the mounts one by one and propping the engine up with a jack. It might not work but its cheap and worth a try.
Old May 8, 2009 | 02:29 PM
rexload's Avatar
when the engine is idling ~950rpm or lower, everything is really quiet (there is some vibration but it is VERY quiet)
but when engine is cold and idles 1500-1700rpm, it is really noisy in the car. it sounds like I am sitting IN the engine bay right next to the engine.
when i am driving the car it is always very noisy. it sounds almost like there is no firewall and like the exhaust pipe goes through the cabin. (but my exhaust is actually quiet)
and when I am getting close to 7000rpm it feels like I am sitting on top of the engine!
the only times when it isn't crazy loud is when I am cruising around 2000rpm in 5th gear
i love driving the car and drive it almost everyday but the noise gets really annoying
i recently took off all mounts and did some grinding. i basically looked at some stock Honda mounts and made my aftermarket mounts look like that, making sure the main base part of the mount is at least .5" away from the mount brackets in the engine bay. sorry, i hope this doesn't sound too confusing.
but what i did made very little difference, so i am thinking that the urethane in the mounts is too hard OR all Civics with F/H swaps vibrate like this?
Old May 8, 2009 | 06:22 PM
rexload's Avatar
I think that the transmission mount could be the main reason for all the vibration because it is so small in diameter. The reason why they make them so small is because there isn't enough room in an F/H Civic for a regular size mount on the transmission side.
So I've been thinking about making a custom transmission mount. First I would have to relocate the mount bracket. Either make it ~5" higher which would allow using a bigger mount... and I could probably even use a stock Honda mount but it would have to be modified of course. OR I also thought about making a custom bracket that will bolt to the transmission and custom dual transmission mounts that will also be stock Honda mounts - one behind the tranny and one right in front.
And after making a custom tranny mount, I would also change the rear and drivers side mount for noname mounts that come with soft rubber.
I think all that SHOULD eliminate a lot of the vibration but making a custom tranny mount is going to be a lot of work...
any thoughts on this?
Old May 9, 2009 | 05:10 AM
kp's Avatar
kp
Did you rebuild this motor in any way before you installed it? Is it running correctly?
I'm just now starting to think slightly outside the box of this thread. If you did rebuild it...is your rotating assembly balanced? Do you have any misfires? Is your ignition timing set up correctly?
If you had an off-balance crank/rod/piston assembly, it would cause a constant vibration. If you had misfires you would feel some vibration and maybe noise as well, but you'd also feel a lack of power and a weak idle. And if your ignition was slightly off, it could also cause some unwanted vibration.
Just throwing it out there.
Old May 10, 2009 | 12:03 PM
rexload's Avatar
yes the engine is definitely running correctly. I had an H22 in the car last year and it made the same exact noise/vibration.
anyway, I made a custom mount for the drivers side today. I used an Accord mount filled with some soft urethane.
I basically took the aftermarket mount i had and cut it in half and then welded the accord mount to it.
honestly I wasn't expecting to notice anything after doing just one mount because I know most of the vibration is PROBABLY caused by the transmission side mount.... I basically did drivers side mount first because it was very easy to get to...
so I put this mount in the car just 20min ago and drove it.... WOW it made a HUGE difference, HALF of the vibration is gone. I cannot wait to change the other mount to stock Accord mounts!
Old May 10, 2009 | 01:19 PM
97ShLude's Avatar
So let me get this straight.....
You took the sound deadening material out of the car and you're complaining about the added noise? Hmmm...... is this a joke?
Old May 10, 2009 | 03:56 PM
rexload's Avatar
why would this be a joke?
removing the sound deadening material adds very little noise that isn't even noticeable at all (i did it because it is 22lbs of dead weight, yes it is actually 22.0lbs)
it is NOT comparable to the noise that I was describing that was caused by the crappy mounts.
the noise was so bad that if felt like i was sitting in the engine bay right next to the engine and the exhaust was right next to my ear. the little noise that is caused by removing the sound deadening is NOWHERE NEAR this
fortunately i realized that i can fix it by making custom mounts using accord mounts
Old May 10, 2009 | 10:14 PM
DocHudson's Avatar
just a random thought..are you still using the balancer shafts of the engine?
cruizer
Sep 15, 2009 07:24 AM
hybrid2007
Jun 25, 2007 11:00 AM
pauld
Feb 18, 2007 06:20 AM
92 CIVIC HATCH VX
Nov 11, 2005 10:28 AM
Jurassic Four
Jun 27, 2004 10:04 AM
