Aftermarket EG suspension fit an EK?
Old Apr 30, 2009 | 05:35 PM
Momentum's Avatar
Default Aftermarket EG suspension fit an EK?
Does anyone know if aftermarket EG suspension will bolt up to an EK Hatch?
Im specifically looking at K-Sport Kontrol Pro, on the website they have different part numbers but the same spring rates
Old May 1, 2009 | 12:36 PM
Momentum's Avatar
Default Re: Aftermarket EG suspension fit an EK?
bump
Old May 1, 2009 | 12:38 PM
dmotoguy's Avatar
yes, you will need to use washers on the rear lca mount because the eg is wider than the ek.
Old May 1, 2009 | 02:02 PM
Momentum's Avatar
Ok cool, would aftermarket LCAs fix this or are they the same width as stock?
Old May 3, 2009 | 09:30 AM
Momentum's Avatar
ttt
Old May 4, 2009 | 12:29 PM
dmotoguy's Avatar
Don't take my word too serious, because I have never done that.. but eg LCA's should fix that.. but I'm not 100% positive they are the same dimensions though.
Old May 4, 2009 | 12:41 PM
gsrpedro's Avatar
no they r shorter
Old May 4, 2009 | 01:56 PM
shak3yb0n3z's Avatar
i'd do some research if i were you. when shopping for suspension for my del sol, i saw that 92-00 were all the same for front and rear struts
Old May 4, 2009 | 02:16 PM
Inliner's Avatar
EK LCA's are longer than EG LCA's you can use EG suspension on an EK all you need are 2 thick washers for each lca...Skunk2 sends washers in there kits for use on EK's.
Old May 6, 2009 | 10:43 AM
Momentum's Avatar
Another question... When removing the rear damper fork bolt on the EKs do these break easy? Do we reuse the stock bolt with the K-Sport coilovers or does it come with a new one?
evo951
Apr 12, 2010 10:53 PM
1 jonesie
May 20, 2007 05:08 PM
platinumg2
Suspension & Brakes
Nov 17, 2005 08:23 AM
Demon_Dub
Sep 25, 2005 01:18 PM
Todd00
25
Jun 13, 2003 09:50 AM
