missing screw?
Old Apr 30, 2009 | 10:48 AM
nateb22's Avatar
Default missing screw?
i bought my 94 del sol last week and am just now getting around to workin on it
but i have a question
in this photo
http://www.facebook.com/album.php?ai...&id=1175381891
is there supposed to be something?
there are threads but nothing else
its right in the middle pf the pic
Old Apr 30, 2009 | 10:52 AM
JarvisW's Avatar
Sol to Sol
Default Re: missing screw?
use flickr, not everyone uses facebook. Or upload it to your post from your computer
Old Apr 30, 2009 | 10:55 AM
nateb22's Avatar
i think it should be in this post
the fb thing was my bad
the hole is .564in deep
Old Apr 30, 2009 | 11:02 AM
sp00ledbseries's Avatar
there is supposed to be a 10 mm bolt with a ground wire going to your core support
JarvisW's Avatar
Sol to Sol
Yep
Old Apr 30, 2009 | 11:06 AM
nateb22's Avatar
wel **** diagrams??? or pics?
Old Apr 30, 2009 | 11:09 AM
JarvisW's Avatar
Sol to Sol
Its the wire thats hooked to the P/S bracket in that pic.
Just a wire, that runs to the body to ground the engine. Probably works just as good where it is now.
Old Apr 30, 2009 | 11:10 AM
cpl rampage's Avatar
you already have the ground its just screwed to your power steering bracket, Ive seen cars with them both ways. it shouldn't matter.
Old Apr 30, 2009 | 11:13 AM
nateb22's Avatar
shouldnt???
Old Apr 30, 2009 | 11:16 AM
JarvisW's Avatar
Sol to Sol
No. Its a GROUND. think of the whole engine as a wire, you can ground it to ANY part of the engine, and it will all be grounded the same. Same as the body, its equal to the negative terminal on the battery. If you look, you will see that cable just connects straight to the body.
Old Apr 30, 2009 | 11:23 AM
nateb22's Avatar
i know its a GROUND thats why its called a ground wire, i was concerned about it because ive seen cars with rubber inbetween the bolts that hold the power steering to the engine, therefore breaking the circut, ITS MY CAR I DONT WANT TO **** SOMETHING UP.
Last edited by EL Vap133; Apr 30, 2009 at 12:19 PM. Reason: Edited the harsh and uncalled for response.
Old Apr 30, 2009 | 11:51 AM
JarvisW's Avatar
Sol to Sol
I wasnt an *******.
Just because you don't know basic electronics don't mean you have to jump ugly on me.
Old Apr 30, 2009 | 11:56 AM
nateb22's Avatar
i do know basic electronics, i havent taken my meds or been to anger managment in a while. I realise that i was an ******* and i am truly sorry.
Old Apr 30, 2009 | 11:57 AM
RunninEg6's Avatar
its all fine so dont worry about it.
JarvisW's Avatar
Sol to Sol
No problem. Apology accepted.
Even tho you're an Okie LMAO!! :D
Old Apr 30, 2009 | 11:59 AM
nateb22's Avatar
i was born and raised in arlington
i moved here because arlington is a ghetto now and oklahoma costs less to live in
Old Apr 30, 2009 | 12:02 PM
JarvisW's Avatar
Sol to Sol
Thats for sure!
And its all good. Good luck with the build.
Old Apr 30, 2009 | 12:18 PM
EL Vap133's Avatar
Correct, it is just a ground.
Old Apr 30, 2009 | 12:20 PM
nateb22's Avatar
you were like 5 posts too late
Old Apr 30, 2009 | 12:24 PM
EL Vap133's Avatar
It doesn't matter, I am confirming it.
samantha ross
Engine Management and Tuning
Aug 11, 2017 07:10 AM
Uljima
May 4, 2014 10:24 AM
Tatakai
Apr 20, 2006 06:12 PM
