jdm h22a idling is fine except when..
Old Apr 30, 2009 | 10:11 AM
wtfitzphat's Avatar
Default jdm h22a idling is fine except when..
it idles fine, but when the car sits at a stop for too long or when i turn the high beams on, or when using the a/c.....the idel will drop considerably low. that's the alternator right? is mine getting old? hmmm let me know what you guys think. thanks
Old Apr 30, 2009 | 02:57 PM
1GPlusSH's Avatar
Default Re: jdm h22a idling is fine except when..
I think you should take it to an autoparts store and get them to test your battery and alternator. If it's not your alternator(which it probably is), then worry about what it could be.
Old May 1, 2009 | 07:47 AM
wtfitzphat's Avatar
thanks bro, any other input from anybody else?
Old May 1, 2009 | 09:49 AM
Honda Sport's Avatar
adjust your idle speed load on/off.
Old May 1, 2009 | 10:52 AM
1GPlusSH's Avatar
no, do not do that.
Old May 2, 2009 | 07:58 AM
wtfitzphat's Avatar
what is idle speed load on/off? what the heck is that
Old May 2, 2009 | 09:50 AM
SKDRCR's Avatar
Is the belt tension itself good? It should have about a 1/2 inch play each way
for every foot of belt between the pulleys.
Old May 2, 2009 | 10:02 AM
92eg_h22's Avatar
its your battery...mine just went through that. burned a starter out and a main relay....it was a shitty day. Go get a new battery before that gets worse. I had the exact same symptoms then BAM! one day my **** doesnt turn over. All i needed was a battery with enough cold cranking amps to do what it had to do. i waited too long.
Old May 2, 2009 | 11:35 AM
1GPlusSH's Avatar
it adjusts your idle up and down...it goes around the problem instead of just fixing it. getting your alternator and battery checked is easy to do.
Old May 3, 2009 | 08:08 AM
wtfitzphat's Avatar
okay, i'll have my battery and alternator checked by monday afternoon. As far as alternators, the jdm h22a alternator should be the same as the motor on the 1992 prelude Si correct? i'm thinking all the alternators for the h series are the same? how about the F series. just in case if it was my alternator, i'll change it, but i need to know if it's the same. thanks
Old May 3, 2009 | 09:13 AM
1GPlusSH's Avatar
i put my 97 SH alternator on my 94 jdm. i'm assuming they're compatible. you'll have to do some checking for the f series. i wouldn't be surprised if they worked.
Old May 3, 2009 | 09:36 AM
Vtec's My Anti-Drug's Avatar
Glad i looked at this because since its finally getting hot out i've been using the A/C and noticing as well that my car idles extremely strange when i kick it on and i saw about someone saying his starter went out and mine i think is going bad because i went to start my car up the other day and it wouldnt and i wasnt a happy camper so glad i came along this. Thanks cause i'll be going to adavanced auto on monday to get the battery and alternator checked out!!
quickster
Jun 24, 2010 10:16 PM
TheMuffinMan
Feb 3, 2008 08:39 PM
civicqm
Aug 13, 2003 09:16 PM
jdmcx
Oct 8, 2002 11:09 AM
crxtreme27
11
Aug 28, 2002 11:29 AM
