Brake light problem
Old Apr 30, 2009 | 08:08 AM
boush95ls's Avatar
Default Brake light problem
I'm having a problem with my brake light when the lights are off and you press the brake it works fine but when you turn the lights on and press the brakes it doesn't light up at all does anybody have any ideas?
Old Apr 30, 2009 | 08:19 AM
Former User's Avatar
Default Re: Brake light problem
Odd electrical problems like this are typically caused by bad ground wire connections. Start by checking and cleaning the ground wire connections in the rear.
Old Apr 30, 2009 | 08:38 AM
SiREJ8's Avatar
Have you checked for corrosion in the connectors/grounds?
Does your horn work? checked fuses?
Old Apr 30, 2009 | 11:18 AM
boush95ls's Avatar
Iv'e checked all fuses and there dine and yeah my horn works. I'll have to check the grounds. There is some corrosion on the socket from moisture in my tailight.
Old Apr 30, 2009 | 12:26 PM
EL Vap133's Avatar
Bad ground, blown fuse, or a short.
Have you done any wiring lately?
Old Apr 30, 2009 | 12:37 PM
honda_1's Avatar
some times its the bulb hae problem so try changing the bulb
Old Apr 30, 2009 | 01:00 PM
boush95ls's Avatar
I changed the bulb already so i'm thinking its a grounding problem i was just confused cause it lights up with the lights off but not when there on
Old Apr 30, 2009 | 01:42 PM
shailoche's Avatar
I ran into the same problem. I ended up having to buy a new bulb socket from a junked car. It seems that the corrosion inside the socket caused the bulb to work intermittently. So, check the socket and see how bad the corrosion is inside it. A new bulb may help because the bulb itself isn't corroded but it is the socket that really needs the help.
devious
Aug 5, 2020 03:45 PM
djevolution04
Honda Civic (2001 - 2005)
Nov 8, 2011 06:47 AM
F r 0 s t t
Dec 17, 2006 05:11 PM
Groove_D
Jun 22, 2004 02:18 PM
guttedEF
Oct 2, 2002 07:27 PM
