caliper lock up
Old Apr 30, 2009 | 06:06 AM
Swansen's Avatar
Default caliper lock up
Like the title says, only its only going forward, it spins freely backwards (reverse). I'm confused, i really don't understand why that would happen, i have new slides, greased, and i would think if the piston was seized it wouldn't spin in ether direction. E-brake issue? It works, and seems to release, the lever and spring move freely, maybe the internal mechanism is stuck?
Old Apr 30, 2009 | 06:46 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: rear caliper lock up
flush out the fluid, put new fluid in and bleed them, new pads, i bet that fixes it
Old Apr 30, 2009 | 06:51 AM
Swansen's Avatar
new pads and rotors all the way around, but i'll try bleeding them.
Old Apr 30, 2009 | 07:38 AM
Former User's Avatar
If you pivot the caliper away from the rotor, does the rotor now spin freely in both directions?
Old Apr 30, 2009 | 08:11 AM
Swansen's Avatar
The caliper is hard mounted, how would i move it? Oh wait, i think i see now, are you suggesting take the caliper off the rotor and see if it spins? Yeah, when i was putting everything back together it spins in both directions fine. Originally i thought the e brake was stuck, because it had been sitting on for a good while, but it seems to move freely. Then once i took the calipers apart i noticed that the pins hadn't been greased and were seized, so i replaced the pins, but no avail..
Old Apr 30, 2009 | 08:16 AM
Again pivot the caliper away from the rotor and verify that the rotor still spins freely in both directions. If so, carefully inspect the area of the caliper where it contacts the rotor to see whether the answer to the problem lies there.
Old May 4, 2009 | 05:58 AM
Swansen's Avatar
Default Re: caliper lock up
Ok, all figured out, as well, it was every caliper, i don't think sitting for as long as it did helped my situation ether.... The parking brake was sticking a little bit rear drivers side, but broke it free. Otherwise, i just took the calipers off all corners and pressed the pistons in, let them come out, pressed them back in and held them for a minute, greased all the pins and contacts on the pads and shims and i'm golden, no more seizing. However, the fluid is looking pretty poor, need to get some russels speed bleeders and do work.
jonyi27
Aug 30, 2013 11:49 PM
SiRkid
Apr 29, 2009 08:00 PM
oMek
Jun 9, 2006 12:30 PM
st0ne
11
Jun 4, 2003 03:41 PM
Inaniac
Jul 4, 2002 01:18 AM
