new coilover setup what do i need?
Hey guys. I have a set on F2 type 1's on the way. I've never installed a susp before and I have a set of blox lca's and a beaks bar to put on as well.
I need to know if there's any bushings or anything that I need to replace that doesn't come with the parts. I know I wouldn't have to replace them if the bushings are still in good shape but I'm going to get them anyway just incase so I won't have to put the install on hold.
So pretty much what I need to know is there anything else I need to pick up to install my coilovers, beaks bar and my lca's.
Thanks
Thanks
Try searching!!!!
Instead of just flaming, ill help you out:
This should help you with your F2 install
https://honda-tech.com/forums/acura-integra-type-r-8/koni-shock-install-56k-burn-891136/
And to change out LCAs is ridiculously easy! Remove the bolts that connect to the LCA, put on new LCA, re-install bolts (not forgetting to add the BEAKS on the corresponding bolts and DONE!
kcjohnnyboy
Suspension & Brakes
Mar 23, 2008 06:31 PM
Manolo
Suspension & Brakes
May 12, 2006 11:36 AM
Shaun98si
May 5, 2005 11:13 AM
