CEL with new exhaust whats the fix?
2000 integra gs. So is there a 02 simulator i can make or buy that will cure this. I tried searching around and found a thread on how to make one but seemed a little easier to just buy one.
did you buy a catback, axleback, or what? i had no issues when i put my apexi ws2 catback on. if you didnt connect your o2 sensor correctly into the catalyic converter that could be the problem.
ITR header and piping all the way back. bung is welded in good and its screwed and plugged in right. Happened after i put the exhaust and the cel points towards 02 sensor
Computer was reset and it cleared the code for a little while then came back on. The 02 sensor isnt even that old maybe like 20k miles
