mounting b series to a engine stand
Old Apr 28, 2009 | 05:04 PM
jdmthug's Avatar
Default mounting b series to a engine stand
so i grabbed up a engine stand for my honda build to make things easiter on myself...well the problem that i have noticed is that the bolts that go to the trans are too short...i saw online something for the d series to use a longer set of bolts but thats not happening for me...no hardware place has the bolts i need...does anyone have any input on this...should i saw down the holes down on the arms just a bit to accomodate this problem or what...
Old Apr 28, 2009 | 05:13 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: mounting b series to a engine stand
Wow I LITERALLY just got an engine stand and was going to put my B16A block on it tomorrow. I didn't even think of that.
In for answer.
Old Apr 28, 2009 | 05:18 PM
jdmthug's Avatar
yeah umm we are both in the same boat right about now...and 12mm x 1.25 x 90mm is a hard *** bolt to ****ing find believe me when i say that..3 stores and nothing my man..my pops went to fastenal and they said expect to pay 25-50 for the bolts....thats for 4 of em...i think i might have to that route i really do need em too
Old Apr 28, 2009 | 05:41 PM
miguel329's Avatar
holy ****! did you try google to see if you can find them or even maybe a place that works on hondas? maybe someone like benson would know since they build engines.. thats way to much for 4 bolts ... dont know if this will help but worth a try...
http://www.google.com/search?hl=en&q...5+x+90mm+bolts
Old Apr 28, 2009 | 05:50 PM
h_s's Avatar
h_s
try finding ready-rod with that thread, then build your own bolts, if that isnt available, go to a boneyard and try to find similiar ones, maybe the lower strut mounting bolts off some import? worst case use undersided bolts and a nut on the other end of the tranny.. (kind of sketchy but it'll do
Old Apr 28, 2009 | 07:13 PM
Wikedeye's Avatar
I used bolts from home depot and just got them long enough to put a nut on the other side. My block has been on a stand for months now with no problems.
Old Apr 29, 2009 | 03:09 PM
BryanM.'s Avatar
Resident Gearhead
The Home Depot and Lowe's in my area didn't have what I needed.
Old Apr 29, 2009 | 04:56 PM
dmotoguy's Avatar
Alright guys, its not that hard... use the bolts you would normally use to bolt the tranny on! I had to make adapters for my engine stand, they are ~6" long peices of steel square tubing with holes in each end.. not sure if you need to do that on all engine stands.
Old Apr 30, 2009 | 03:27 AM
BryanM.'s Avatar
Resident Gearhead
The tranny bolts are 3 3/4" too short for that stand I am trying to use.
Old Apr 30, 2009 | 04:23 AM
alphalanos's Avatar
boltdepot.com
Old Apr 30, 2009 | 01:24 PM
packman5280's Avatar
ace hardware. i bought the bolts there, couldn't use the stock bolts because they were still holding the trans to the old motor, int he car, and i needed to get the new motor ont he stand.
Old Apr 30, 2009 | 01:35 PM
BryanM.'s Avatar
Resident Gearhead
Got the ones I needed at NAPA.
Old Jun 20, 2009 | 07:13 PM
BucCivicSi99's Avatar
im in the same boat right about now.,.,so all NAPA carry them (12mmX1.25X90mm) rite??
Old Jun 21, 2009 | 06:25 AM
BryanM.'s Avatar
Resident Gearhead
Hard to say if all NAPA stores carry them. Call around and ask.
The NAPA I got my bolts from is also a machine shop and they carry a lot of odds and ends that a "regular" NAPA my not have.
Old Jun 21, 2009 | 06:29 AM
pythoner's Avatar
I went to lowes and got a bolt that was a little smaller than the non threaded holes and then got washers and nuts... I had it like that for months while getting my car re painted
Old Jun 21, 2009 | 05:17 PM
thank guy..,,.i when to Home Depot get em 12m x 1.75 x 80mm and a 12mm washer work fine.,.8)
nico91civic
Jun 20, 2009 07:14 PM
tkda
Mar 12, 2009 11:33 PM
SleepyHatchZ6
Feb 27, 2009 08:34 PM
import-tooner
Dec 28, 2004 12:08 PM
Gonzo_SiR
Nov 3, 2003 07:03 PM
