2000 civic DX check engine light code
P0420 Catalyst System Efficiency Below Threshold
P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System)
top of tread there is a post of codes.
but i checked for you.
b-town bump
b-town bump
A very common late 90's code, P1457 is a failure in one of the evap system solenoid valves. There are 2 culprits, the Vent Control Valve & the 2 Way Bypass Valve. They are located under the vehicle, roughly below the left rear seat area. They short out due to corrosion/contamination from water seeping into the valves. I changed both, but the real culprit seems to be the 2 Way bypass Valve.
jeremy8886
Dec 7, 2005 06:54 PM
