Check engine light problem
Old Aug 27, 2009 | 10:58 AM
XrainmanX's Avatar
Default Check engine light problem
Hello HT,
I have a 2000 Gsr coupe with around 68k miles and my check engine light is on. I scanned the code and it says " Auxiliary Emissions Control"( Forgot the actual Code number). Anyone know what that means? Any help would be appreciated.
Thanks!
Old Aug 28, 2009 | 06:51 AM
XrainmanX's Avatar
Default Re: Check engine light problem
bump. Anyone?
Old Aug 28, 2009 | 07:52 AM
follie gatts's Avatar
that description doesn't match anything in the list linked in my signature "CEL Trouble Codes"
you probably need the code number
Old Aug 29, 2009 | 12:47 PM
XrainmanX's Avatar
I got the codes with the descriptions...
P1259 VTEC Malfunction
P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System)
Old Aug 29, 2009 | 12:50 PM
XrainmanX's Avatar
Has anyone else had these CEL? what did you do to fix it?
THanks!
Old Aug 29, 2009 | 02:37 PM
axelintegra's Avatar
it sounds like maybe the o2sensor in your cat could be triggering it.
xcv2dgru
May 18, 2017 06:05 AM
h22egAZ
Apr 28, 2009 08:55 PM
CRX2NV
Apr 29, 2003 11:40 AM
97gSrkId88
Mar 20, 2003 11:06 PM
