Bitch Pin... Removing w/ Ball Joint Press
Old Apr 28, 2009 | 11:48 AM
aalb1's Avatar
Default Bitch Pin... Removing w/ Ball Joint Press
I know some people have success with using a Big F'in Hammer with removing the Shift Linkage Pin but for it doesn't work. So does anyone think that one of these Balljoint presses will work with pushing the pin out?
I have access to borrow one of these and I want to have my bases covered in case the BFH route doesn't work.
Old Apr 28, 2009 | 12:04 PM
rudebwoy's Avatar
Default Re: Bitch Pin... Removing w/ Ball Joint Press
you guys make it seems so difficult to remove the spring pin from the shifter.
using that tool would make the job harder in my opinion.
all you need is 1/4" align punch , and 2lbs sledge hammer, 5 to 8 steady taps and its out, same thing to put it in. too easy sarge!
Old Apr 28, 2009 | 12:15 PM
R666_EK's Avatar
Yeah its really not that hard. But if you for some reason cant get it out, then that would probably work. I've seen people use C clamps to get em out.
Old Apr 28, 2009 | 12:23 PM
prwil3030's Avatar
Using a press for this pin, that's xtreme.
Old Apr 28, 2009 | 12:24 PM
raidacaipo's Avatar
if you cant find a punch then look around your garage for a flat head screw that will fit thru the hole but not small enough to go thru the pin and stick it in there and punch it out..
Old Apr 28, 2009 | 12:33 PM
Pothole987's Avatar
Punch it out with your fist? wow that must be easy ...
Use a hammer and hit the screwdriver/punch with everything you've got. it'll fall out in 3 swings max.
Old Apr 28, 2009 | 12:37 PM
Mashimaro's Avatar
If you have access to an air compressor, the pin only takes a few seconds going in out with an air-hammer/chisel with a punch-like bit.
Old Apr 28, 2009 | 12:48 PM
aalb1's Avatar
Hmm now that you said it I came across this http://www.performanceforum.com/wesv...tch/bitch.html
I never new some people used a c-clamp... and to think I was original!
Old Apr 28, 2009 | 12:49 PM
raidacaipo's Avatar
Its common sense to use a hammer smart ***... otherwise I would have suggested a rock
Pothole987's Avatar
not really original i bet someone else has done that before. if there was a smaller ball joint press it'd be ok, because of the hole in the end just push it up through and be good.
Old Apr 28, 2009 | 12:50 PM
Pothole987's Avatar
Good idea, i'll use a rock to remove a pin... god great way to confuse everybody.
Old Apr 28, 2009 | 12:52 PM
raidacaipo's Avatar
Its not my fault you take the word "punch" literally.. dumbass.. the only one whos confused is you if you dont know what sarcasm is
Old Apr 28, 2009 | 12:56 PM
aalb1's Avatar
Nobody is confused... it's just you.
Old Apr 28, 2009 | 12:57 PM
Pothole987's Avatar
ladada who doesn't know what sarcasm is... you gotta remember people aren't as well educated as people like me.
Old Apr 28, 2009 | 01:06 PM
speedooo's Avatar
I have 3 of these...the handle is the PERFECT size
http://www.sears.com/shc/s/p_10153_1...et+Accessories
Old Apr 28, 2009 | 01:53 PM
RunninEg6's Avatar
i didnt have those to start but went out and got a punch set w/hammer and maybe 20 deadblow swings later it eventually came out
PrettyMuchBoned
Apr 24, 2014 07:20 AM
freddysEF
Jan 17, 2008 07:13 PM
Mavrick
Nov 12, 2005 11:00 AM
Mavrick
23
Nov 6, 2005 09:44 PM
fe519
Sep 14, 2004 01:45 PM
