Window Motor Failure?
Old Apr 28, 2009 | 11:43 AM
bLaCkNbLueLuDe's Avatar
Default Window Motor Failure?
Recently my drivers side window has stopped going up/down. Whenever i push the button to make it go up/down, i can hear the motor running but nothing happens. To me it kind of sounds like a gear is turning but the teeth is stripped so its just grinding but im not really sure. I can move the window up/down manually so i was thinking that i might just need a new motor but im not sure if i need to get a new regulator too.
Any suggestions/comments before i spend money?
Old Apr 28, 2009 | 04:40 PM
Remiss's Avatar
Default Re: Window Motor Failure?
unbolt the door panel and take a look (btw it gives u like a foot more leg room. I took out my door panels)
then if u can unhook the 2P plugin that goes to the motor and put direct power using a battery, if the motor works u know its not that
odds are its just the main relay switch not sending current to the motor
leeto206
Aug 19, 2012 03:47 PM
GsRrrr
Jun 14, 2011 04:02 PM
da_ska
May 31, 2009 02:32 AM
streetlights
Dec 5, 2008 10:06 AM
spinez
Mar 20, 2005 11:03 AM
