starting air valve?
Old Apr 27, 2009 | 10:49 PM
hondaequikppd1's Avatar
Default starting air valve?
im a turbo newbie, and i recently had a turbo system installed on my 96lude h22, my ? is, do i need to somehow re-connect the "starting air valve" vaccuum hose to the charge pipe? this pipe did not have a fitting for it, but i do know that this hose was connected to the stock intake pipe, i've been driving with it disconnected quite some time now..
Old Apr 27, 2009 | 11:51 PM
LobeSex's Avatar
Default Re: starting air valve?
well im not turbo but im cam'd and piratemcfred sold me a SAV blocking plate(got rid of the SAV) for 7bux so id ask him if that would help ur application
Old Apr 28, 2009 | 12:56 AM
whats sav?
Old Apr 28, 2009 | 01:25 AM
aasaa666's Avatar
SAV is the topic you brought up. Starting Air Valve - SAV
Old Apr 28, 2009 | 01:42 AM
oh duh, sorry, ya you think itll help?got pic?
Old Apr 28, 2009 | 01:42 PM
LobeSex's Avatar
this is the picture that piratemcfred posted on my thread...
Old Apr 28, 2009 | 07:20 PM
ah, cool does it run okay like that? what is the benefit of blockit the sav?
i sort of simulated that, or at least i think i was, what i did was put my finger on the sav vacuum hose while the car was running, i felt suction, i then revvd it up alil, and the rpms climb, and the rpm decreases very slowly, when i let go of the throttle, while doing this, i noticed a popping noise...is this way the same thing as if i were to eliminate/add block plate as shown in your pic?
Old Apr 28, 2009 | 07:31 PM
LobeSex's Avatar
im not 100% the reason why i did this is because my idle surged big time and when i took it off it stoped surging so like i said just PM pirateMcfred he should know if it will benifit your application
Old Apr 28, 2009 | 08:28 PM
red92si's Avatar
My JDM H22A came with no starting air valve and instead has a factory block-off bolted on. Starts and idles fine.
Old Apr 28, 2009 | 09:53 PM
oh okay, hey thanks alot guys, ya ill try n pm him
Old Apr 29, 2009 | 01:37 PM
Hawkze_2.3's Avatar
Damn, you're a total car newbie, haha jk. The SAV just provides a bit more air startup, and it is not needed.
You can make a plate out of anything, just cut out the right shape. My plate is made out of a slice of carbon fiber from the bottom of my hood...works fine.
You felt suction because the engine creates vacuum. It won't run any different if the valve is hooked up or not provided you don't have a vacuum leak.
Old Apr 29, 2009 | 07:48 PM
haha yup newbee hea.thanks guys
Old Apr 29, 2009 | 10:15 PM
LobeSex's Avatar
well it made a difference with mine way after it was started it surged like crazy and wen i disconnected it, it ran perfect
Old Apr 30, 2009 | 07:27 AM
Hawkze_2.3's Avatar
:p
Old Apr 30, 2009 | 07:33 AM
jordan_rael_420's Avatar
Yup my JDM h22 came stock like that too!!
Old Apr 30, 2009 | 10:25 AM
mattsnooz's Avatar
Lots of the parts in your car essentially "do nothing"
Like the horn for instance. What are you going to do with that? Chances are your just going to yell obsenities anyway
Old Apr 30, 2009 | 04:23 PM
LobeSex's Avatar
trust me talk to pirate about it he will tell u it makes a diff...atleast with stage3 cams like my application
Old Apr 30, 2009 | 06:16 PM
PirateMcFred's Avatar
Mattsnooz, if you've been around you might have noticed that my engine's a little different than most. Removing the SAV helped my setup big time. On a VTEC engine that pulls more than 700mbar manifold pressure at idle the SAV is fine to run. The POS SAV on a big cammed engine causes a surge at idle. If you're mostly stock it wont' do a bit of good for you to remove it. It didn't come on engines from JDM land, as was said before and it's not necessary. If it's not necessary then remove it.
You're free to do to your engine what you like. On mine I'll do what I like.
Old Apr 30, 2009 | 09:07 PM
LobeSex's Avatar
get 'em pirate
dannyly17
Jan 14, 2011 08:20 AM
cslegacy
May 20, 2008 06:53 PM
redLUDEs2k1
Oct 14, 2005 06:40 AM
2000vsm
Aug 18, 2003 05:33 AM
