no cluster lights
Old Apr 27, 2009 | 03:50 PM
BeRightBack's Avatar
Default no cluster lights
alright so the other night I went to get into my car and start it up, flipped my lights on and my cluster won't light up. I have power to everything else, the directionals work, high been light, oil light, all that works just fine. It's just the cluster bulbs that won't work. I checked them, and replaced them, they are new and not the problem. Any ideas on what I could be? if it's an easy fix then I'll get it done, but if it's a wiring problem then I'll probably just get some el glo gauges from speedhut.com
Old Apr 27, 2009 | 04:31 PM
JDMInteg96's Avatar
Default Re: no cluster lights
check your fuse box... and make sure you are gettin power to them... i believe under the dash there is a 10 or 15 amp fuse that is for instrument bezel
Old Apr 27, 2009 | 05:05 PM
yes I checked the fuse. It was blown so I replaced it hoping that would solve the problem but it didn't
Old Apr 27, 2009 | 05:06 PM
HCKRU's Avatar
15 amp fuze in the fuze box under the hood. had the same thing happened about a month ago.
Old Apr 28, 2009 | 11:43 AM
there is no fuse for the lights under the hood. The only one for the cluster is under the dash
Old Apr 28, 2009 | 11:57 AM
HCKRU's Avatar
i guess it depends on the model, my 95 Ls Teg has quite a few fuses under the hood, i changed the blown one and everything works. just check for blown fuses. will never hurt to change out some blown ones you don't know about
hope this helps
Old Apr 28, 2009 | 12:51 PM
JDMInteg96's Avatar
did it blow the fuse again?
Old Apr 28, 2009 | 01:02 PM
HCKRU's Avatar
i was doing tan to black interior conversion and did a lot of electrical work, such as relocation of the ECU, speaker wireup from amps, battery relocation, ETC. i have blown fuses a lot, but the cluster only blew once after i replaced it, but now i know all the diagrams and electrical fundamentals of my car, i got a PDF image of the integra manual, with all the electrical diagrams and **** if anyone needs if PM me i got it
Old Apr 29, 2009 | 08:46 AM
no it didn't blow the fuse again
I have a 96 ls
Old Apr 29, 2009 | 09:26 AM
jdm_bones's Avatar
remove the cluster and check all the bulbs, as there might be one or more out! Ground issues might also cause something like this to happen!
Old Apr 29, 2009 | 09:50 AM
the four bulbs in the cluster are brand new they just came in front superbrightleds.com
which ground wire would it be for the cluster? I checked all of the one's that I could find or think of.
Old Apr 29, 2009 | 11:01 AM
come to find out my plate lights don't work either lol
Old May 20, 2009 | 09:22 PM
F20EG's Avatar
check your dimmer switch
Old May 20, 2009 | 09:37 PM
NAV_GUNZ's Avatar
Have to agree... I had the same situation go on with me. I even bought a second cluster thinking something was wrong with the one I had. It ended up being the 10$ dimmer switch...
Old May 20, 2009 | 11:30 PM
RealRaw's Avatar
I had the same problem... i swapped out a bulb in my cluster and burned the fuse.. i replaced the fuse and it worked for a few minutes and burned again. i ended up going with a higher amp fuse.. works fine for a few weeks now.
Old May 21, 2009 | 08:49 AM
calboi's Avatar
i am having the same problems lmk what you come up with man thanks
silverboost
Jan 2, 2007 01:52 PM
rodimus
Aug 3, 2005 06:57 PM
mrbsponge
Dec 31, 2003 03:31 PM
serboy00
Dec 20, 2003 06:49 PM
BrynnTheSlut
Aug 7, 2003 09:14 AM
