Need help car smokes
Old Apr 27, 2009 | 01:23 PM
GSR936's Avatar
Default Need help car smokes
i got a 96 acura integra gsr i got it and never smoke at all. but now its starting to smoke at high rpms does not brun oil ,the color smoke is graysh and bluesh.
Old Apr 27, 2009 | 01:42 PM
JDMInteg96's Avatar
Default Re: Need help car smokes
does it smell sweet? are you losing coolant? does it seem like your car is wasting more gas...some things to think about
Old Apr 27, 2009 | 03:30 PM
GSR936's Avatar
yea it does waste gas and coolant
Old Apr 27, 2009 | 03:32 PM
GSR936's Avatar
i have a cel for missfire on #1 #2 cylinder
Tarmac Junkie's Avatar
Rings starting to go mabee. Valve guild seals?
Do a compession test and a leakdown test..
Old Apr 27, 2009 | 04:27 PM
JDMInteg96's Avatar
compression and leak down is the best way to start
Old Apr 27, 2009 | 04:28 PM
JDMInteg96's Avatar
could also be a blown head gasket that is causing coolant to seap into cylinders and cause misfire and detonation... which can cause fatal damage to walls and pistons
Old Apr 28, 2009 | 04:23 AM
GSR936's Avatar
Ttt
Old Apr 28, 2009 | 06:00 PM
fsg231's Avatar
blown headgasket.... goodtime to resurface the head, and valvetrain work.
Old Apr 28, 2009 | 06:10 PM
dr.garagetuner's Avatar
seems like valve stem seals or could be a bad head gasket. get a combustion leak detector to check and see if you have a bad head gasket, and do a compression test along with a leak down test. that will tell you alot with out having to take anything apart first.
Red-Rag-B18
Aug 23, 2010 05:33 PM
88 EF Hatch
Jul 11, 2009 09:50 PM
som3on3_10
May 20, 2006 05:49 PM
JTCdudeman
Sep 24, 2005 07:23 PM
FLIPboi
Dec 4, 2002 03:25 PM
