Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
honda civic04 overheating problem
Old Apr 27, 2009 | 11:15 AM
hondanewbie8181's Avatar
New User
Default honda civic04 overheating problem
My honda 04 civic sedan keeps overheating intermittently. I brought it to the dealership and they replaced the thermostat. As soon as it left I notice the radiator was always a quart an half low and my overflow tank is filled up to the neck. I took it back to the dealership two weeks later and they couldn't figure out whats wrong with it. they told me the thermostat is ok and suggested my radiator or waterpump be replaced. I had my waterpump replace about 6 months ago and so I decided to have them replace my radiator to see if that was the problem.
The problem still remains, my radiator is still low in coolant and it keeps pushing coolant to the overflow tank. My car is still overheating intermittently. I don't want to take it back to the dealership because they are just gonna suck more money and give me the run around again. any suggestions?
thanks,
Old Apr 27, 2009 | 11:21 AM
It Wasn't Me's Avatar
Default Re: honda civic04 overheating problem
Guidelines: https://honda-tech.com/forums/honda-civic-2001-2005-78/faqs-guidelines-read-before-posting-2101211/
FAQ's: https://honda-tech.com/forums/showthread.php?t=2247386
Search: https://honda-tech.com/search.php
Use the keyword "overheat" or "overheating" and search the 01 - 05 Civic forum.
Based on your description, and from what I've read within other threads, my guess would be the head gasket.
Old Apr 28, 2009 | 09:41 AM
New User
Default 04 head gasket
does any one know where the head gasket it located on a civic 04?
Old Apr 28, 2009 | 09:43 AM
Harlowe's Avatar
Function>Fashion
Default Re: 04 head gasket
Between the cylinder head and the block....
Old Apr 28, 2009 | 12:13 PM
Curiouz_G's Avatar
you registered for the forum, activated the account, and even posted here, yet you couldnt google it? No worries though, I gotcha back...
http://lmgtfy.com/?q=head+gasket
Old Apr 28, 2009 | 09:20 PM
dtapia's Avatar
sounds like you need a person that knows how to correctly fix your car. this is not for the novice.
Old Aug 18, 2009 | 01:55 PM
JCassidy's Avatar
New User
I have the same problem, but its a 05 Civic EX-Special Edition With 90K+, and the dealership checked the head gasket and pistons and everything looked great, they said it is in perfect shape. I have it in the shop now trying to get it fixed. Ill let you know the outcome.
Old Aug 20, 2009 | 04:53 PM
CD_Ridge's Avatar
It would not hurt for the OP to replace the radiator cap.
Old Aug 21, 2009 | 09:53 AM
redb16coupe's Avatar
im also having the same issue and im going to change the radiator cap today see if it fixes the problem, everytime i open the cap i have pressure inside. im guessing air is getting in somehow.. doesnt seem to be the headgasket though as i dont have a sweet smell coming out the exhaust..
Old Aug 21, 2009 | 02:17 PM
jdmfreak1992's Avatar
The cooling system is under pressure your suppose to have pressure inside it's air bubbles that cause a lot of problems. To solve this.....
First remove the radiator cap and start your car and let it run WATCH THE TEMP if you see your fluid in the radiator start to bubble That means you have air bubbles in your system that could be making it overheat. Let it run until it stops bubbling replace cap go for a drive if that didn't fix it then time to move on to the next step.
Old Sep 26, 2009 | 02:38 PM
emaka9's Avatar
im bringing this alive again cuz i have the same problem on my sisters 02 ex. i changed radiator, thermostat, and water pump. and still over heated! help plz!!!
Old Dec 16, 2009 | 03:39 PM
midnitesol's Avatar
I'm having the same problem with an 04 ex sedan. Blows cold air, fans aren't working. Replaced head gasket, water pump, thermostat, and radiator. I even jumped the plug to get the fans working but still no go. Anyone figure this out ???
Old Dec 16, 2009 | 03:56 PM
You hot-wired the radiator fan and it still didn't work? Replace the fan.
Have you flushed your heater core? Bled the system for air bubbles? All that stuff??
Sl0wH0nda
Jun 13, 2013 10:22 AM
JDM_Silver
May 30, 2007 09:03 AM
CTara12345
Sep 15, 2005 12:31 PM
Lucky2000
Apr 25, 2005 08:33 AM
The-LS
Jul 14, 2004 01:16 PM
