car won't rev
Old Apr 26, 2009 | 07:21 PM
wubanga's Avatar
Default car won't rev
I had just put a new single cam in my civic and now the motor will not rev when I give it gas. Would that be the TPS? Please let me know. Thanks
Old Apr 27, 2009 | 11:17 AM
dephtone's Avatar
Default Re: car won't rev
Does it rev slowly or does it die when you try and give it gas?
Old Apr 27, 2009 | 11:26 AM
wubanga's Avatar
it sucks air into throttle body but will only rev to about 1000 rpm. Idles perfect no smoke and just a temp code on ecu.
Old Apr 27, 2009 | 12:25 PM
dephtone's Avatar
Did you have to convert to MPFI? What motor specifically, which ECU?
Old Apr 27, 2009 | 12:59 PM
wubanga's Avatar
well i had bought the car with a spun rod bearing( it ran great till the motor took a ****) so i put a new d15 back into it. It is all multi point injection and same ecu that was in car when i had got it. Th car starts and like i was saying idles great. No miss fire, No ticks or odd noises. First time i have been stumped this bad.
I realy want to say TPS but throwing no code. Thanks for helping!!!
Old Apr 27, 2009 | 01:48 PM
redflaredcrx90's Avatar
if it were the tpa youd get a code no matter what. check to see if you have any vac leaks. around the manifold did you check timing, and do you have the spark plug wires in the right order
Old May 9, 2009 | 03:53 PM
slowac's Avatar
are there any updates on this? i'm having same problem.
Old May 9, 2009 | 04:26 PM
SquirtleSquadEf9's Avatar
maybe ur throttle cable isnt tight enough or maybe its to tight so it has nothing to pull on......
Old May 9, 2009 | 08:32 PM
hatcht9x's Avatar
could it possibly be a fuel problem? do you have fuel pressure?
Old May 9, 2009 | 08:34 PM
hellraiser7492's Avatar
i was thinking the same thing as i read this post.
Efwithhatch
12
Oct 23, 2012 07:41 PM
Granny_shifter
18
Sep 17, 2012 08:08 AM
Godspeedmj
20
Aug 12, 2010 01:22 PM
fatpride111
Sep 23, 2008 11:33 AM
