Which Exhaust Setup
Im Torn Between 3
Do I buy
1) UniversalMuffler and Get it straight Piped
2) Buy a Cat Back System
3) Cat Back W/ Test Pipe
And Is there a noticeble difference in sound say if i got a HKS Univ Muffler str8 pipe'd
as oppose to a
The Same HKS but as a full cat back?
and recommendations as to what exhaust would be appreciated
ty
Do I buy
as oppose to a
ty
you at least want to run a high flow cat.
no cat hurts performance.
test pipe will get you the best performance, but it'll probably be loud as heck.
high flow cat will fall short of the test pipe, but at least it's there and it won't be as loud. my suggestion is a catback with a high flow cat.
i recommend custom exhaust tubing and either an itr muffler or mugen. i just recently dropped my itr muffler (sounded okay, apparently restrictive though) for my new mugen twinloop. the mugen is damn awesome!
EDIT: HPPPPRAAAAAAAAAAAAAY DRUNKENS!
Do you have anything to back up this claim? Any dyno graphs showing a loss in power when switching to a "straight pipe"? BTW, what are we comparing a "straight pipe" to?
The backpressure myth is a joke. The whole point of an exhaust system is to clear the chamber and bring in a fresh mixture, not choke your motor...correct exhaust diameter is what you need to look at, not backpressure.
I also very much enjoyed my twin loop, previously I had 2.25 with a "hi flow cat", with my new setup I will have 2.5 with a test pipe and my twin loop.
this is the correct answer. it's all about flow. team integra has a pretty good write up on pipe size and the effect on power. if anyone has doubts about this back pressure garbage. think it thought. combustion takes place, exhaust valve opens and the burned cycle is pushed out. if you did create "backpressure" the piston would have to push it out thus loosing HP. what you ideally want is the exhaust being pulled out of the cylinder in a scavanging effect. think about headers and why some make more power than others. it's all about the pull.
When I had my hatch and went from a Z1 to a Z6 I was running the Z1 manifold for a couple of weeks. I bought a header did away with the header/cat and noticed a power loss. My buddy's coupe we noticed the same thing. From my experience if you have a stock motor you will notice a power loss
Im Torn Between 3
Do I buy
as oppose to a
ty
Do I buy
as oppose to a
ty
