Interior clock issue
ok ever since i bought my lude in november the clock has been acting weird......if i set the clock to the right time it will work for a day or so then after its been parked overnight, in the morning it will be set at a totally different time then what it should be at...also when i turn the **** to the right to change the minutes, if i hold the **** the minutes keep going up and doesnt stop until i turn off the car....any suggestions on what it could be? a new clock or **** maybe?? or is it something else...any help is appreciated...i hope i explained the prbolem clearly
sounds like a clock problem, but check the power and grounds to the clock inputs first.
i'd go fetch one from a junkyard and try that one and see if it works.
i was bored, so i looked up the wires on alldata-
hot at all times - white/yellow wire
ign switch power - yellow
ground wire - black
theres 5 wires going to the "time set switch" aka the ****
check both fuses 43 and 13 they both feed the clock power
good luck
ground wire - black
good luck
make sure you dont have an electrical issue. If it isnt then it must be something wrong with the clock. We had a customer that had the same situation. Most of the time the clock will last as long as your seat belt retractors. This indeed is super rare.
OMG THE GOGGLES
May 24, 2006 10:01 AM
