rough idle problem... swapped car
Old Apr 23, 2009 | 05:28 PM
4cyl707's Avatar
Default rough idle problem... swapped car
I have a 94 Eg with a 94 GSR with a S2 Pro series Manifold. Im having problems with a bouncing idle. When the Car is cold the idle jumps up to 3k then drops to 1k and as it warms up the RPM jump decreases to around 2K and drops to 1k or sometimes sticks 2k. There are no check engine lights either. I switch out two different IAC valves in replace of it and still the same thing. I put some PB blaster in the IAC valve to see if it would free up a possible sticking issue? still nothing? I checked the vacuum lines going to to the manifold and the idle didnt change?
any suggestions?
Old Apr 24, 2009 | 04:01 PM
hmoobimage's Avatar
Default Re: rough idle problem... swapped car
check for vacuum leak, what ecu are u running
Old Apr 25, 2009 | 04:33 PM
Trevor Cheong's Avatar
New User
you have totry cleaning your trotle body
Old Apr 30, 2009 | 01:38 PM
KARSON's Avatar
check your valve timing.
Old Apr 30, 2009 | 06:54 PM
KWayRacing's Avatar
Check vacuum leak at S2k manifold flange. Is the throttle cable adjusted correctly. Also what is the position of the idle set screw? Is throttle position sensor adjusted correctly? These are some areas of interest to you. Good Luck
Old May 3, 2009 | 09:23 AM
KWayRacing's Avatar
well?
protopro88
Apr 8, 2011 03:41 PM
luv2boost
Jun 2, 2008 06:33 PM
IntegraType-R
11
Jan 20, 2008 11:23 PM
Midori Green
Jan 3, 2007 03:13 PM
h22831
Jul 18, 2005 06:36 PM
