Bad Oxygen sensor?
I'm getting code 41 and is the only code left to clear. well what I don't understand is that I put this o2 sensor in about 2800 Miles ago by Bosch, could it possibly need to only be cleaned? Its the one on the header.
Is there a crack in your exhaust manifold? If so, this will give you a code 41 as well. And don't use bosch because they're sh*t. You can get an OEM one with the connector at denso.com.
hell yea, theirs about 20 cracks but i welded them closed and i thank it cracked again somewhere else. Dc Sport Header Suck *** just for anyone that wants to throw out 4 bills for some. they do have like 40k miles on them though and been threw 5 different engines.
So if i weld it again will it fix it?
