Help
Old Apr 23, 2009 | 02:47 PM
adammilad's Avatar
Default Help
I have a 1994 Honda civic vx that I swapped a d16y8 into and I need to know which hose connects the water pump inlet pipe. Any help would be appreciated and also if someone has a diagram of were all the hoses go it would be awesome.
I also have another problem the other day when it was snowing my dash and rear light went out, so one day after work I went to change the fuse and it started raining really hard so I changed really fast and got back in the car and started it and the next thing I know the dash lights and taillights work now, but the turn signals, gas, speed, tach, and temp guages do not work, but the hazards work. Let me know what you think the problem is, and thanks in advance
Old Apr 23, 2009 | 03:27 PM
RH2008's Avatar
Default Re: Help
i dnt have them at my current position but there are diagrams for all of this online, part lists n such and online service manuals... i have it all bookmarked but not on this comp, srry i cant be of help but maybe someone else has them, or try google if u havent already
Old Apr 23, 2009 | 03:42 PM
adammilad's Avatar
Default Re: Help
Think u, but I have been searching all day and can't find any diagrams for the d16y8, well if anybody has anything post it up
Old Apr 23, 2009 | 08:02 PM
adammilad's Avatar
Default Re: Help
bump need some help
Old Apr 23, 2009 | 09:05 PM
Former User's Avatar
Default Re: Help
Check whether fuses 15 and 19 under the dash are blown. For the dash lights, also check whether jumping the red and black wires of the connector for the dimmer switch allows the dash lights to turn ON full bright. If so, the switch is bad.
Old Apr 24, 2009 | 08:28 AM
adammilad's Avatar
Default Re: Help
think you sir for the diagram.
and the light on the dash are know working, it was just a fuse. but when i was changing it it started raining really hard, so i got back in the car and the dash lights all work even the hazards. but know almost none of the cluster works the e-brake light doesnt even work but i beleive the srs ligh comes on, and the check engine light doesnt even come on. so i changed the cluster and it didnt help at all.
Old Apr 24, 2009 | 09:00 AM
Default Re: Help
Did you check whether under-dash fuse 15 is blown?
hatchyboy89
Jul 7, 2012 07:15 AM
brendajack
Honda Civic (2001 - 2005)
Oct 30, 2008 08:00 AM
headrec*
10
Jul 15, 2008 10:35 PM
SlowPokeEg
15
Jan 21, 2008 09:31 AM
DOHCgarage919
Jan 15, 2008 12:21 PM
