Switch from 5W30 to 10W30, loss in performance?
Old Aug 15, 2002 | 11:20 PM
Qwikrex's Avatar
Default Switch from 5W30 to 10W30, loss in performance?
Will I notice any loss in performance switching frow 5W30 Castrol to 10W30 Castrol????
Old Aug 15, 2002 | 11:21 PM
bretx0r's Avatar
Default Re: Switch from 5W30 to 10W30, loss in performance? ([VTEC]TL)
no
Old Aug 16, 2002 | 04:00 AM
EKB18BPR3's Avatar
u wont notice cu its a tiny difference...but one's a ticker solution so thereotically ur engine will work slower using thicker oil...but im just talking out of my *** at 6 in 5 in the mornng so dont listen to me
Old Aug 16, 2002 | 04:21 AM
hondafrk's Avatar
Default Re: Switch from 5W30 to 10W30, loss in performance? (dniedacess)
wont make any difference. If you started using straight 40weight then you may notice a small difference.
Old Aug 16, 2002 | 04:34 AM
shawnhayes's Avatar
Come on guys. Let's remember how the rating works. 5W-30, acts like 5 weight cold, 30 weight hot. 10W-30, 10 weight cold, 30 weight hot.
Summary: No difference hot, five weight difference cold. How much difference is that? Not much, but there is some, but it will last for like two minutes during warm up, and no moron goes all out in the first two minutes after the car is on.
Shawn
Old Aug 16, 2002 | 05:21 AM
.paul's Avatar
Default Re: Switch from 5W30 to 10W30, loss in performance? (shawnhayes)
.... no moron goes all out in the first two minutes after the car is on.
Shawn
or so we hope....
Old Aug 16, 2002 | 05:31 AM
g_man80's Avatar
One question (maybe because I drank too much last night, but): wouldn't the 5 weight be thinner than 30 weight (talking about 5w-30), so the oil would act like 30 weight cold and 5 weight hot? Maybe I have it backwards, but I thought the higher the weight, the thicker the oil? Just looking for some clarity. Thanks
G, (whose a little hung over at work)
Old Aug 16, 2002 | 06:38 AM
Qwikrex's Avatar
Default Re: Switch from 5W30 to 10W30, loss in performance? (g_man80)
So then when heated up the 10W30 will act the same as 5W30?
NeedMOPower's Avatar
ya 5 weight is thinner than 30 weight.. 5 weight is used for colder start up temperatures i.e. Cold weather where a thinner oil is need to before the engine heats up. Where as in warmer temperatures you would want a 10 weight.
The main advantage to using a 10W30 is that the operation window is larger it can handle higher temperatures when running. Where a 5W30 cannot handle quite as high a temp. Unless you are in the winter months in Canada you should only need to use a 10W30 motor oil.
And to clerify just like specified above it would be 10 weight cold 30 weight hot.
Old Aug 16, 2002 | 06:46 AM
g_man80's Avatar
Default Re: Switch from 5W30 to 10W30, loss in performance? (kojack)
But what I don't understand is that the oil acts like 5 weight cold and then 30 weight once the engine is at it's running temp. How does the oil get thicker once hot? I would think 5w-30 and 10w-30 would be the same weight cold (30w), but the 5w gets thinner when hot and the 10w would remain slightly thicker (for hot weather).
Old Aug 16, 2002 | 06:56 AM
read the words on the paper not between the lines.....when cold a 5W oil is thinnner...for start up at cold temperature... a 10W oil is thicker so that if it is really hot out the oil will not be to thin. That is what matter the second part i.e. 30,40,50 is the operation thickness of the oil. Just remember that higher second numbers are for higher operational temperatures. That is all you really need to know. If your car is only for autocross allways pounding it on a race track and not operating at cold temp you want to use a 10W 50 better for higher engine temperatures.... Just remember this if you are in a cold climate i.e. winter when it is cold enough for snow to be on the ground use a 5W motor oil if the temperature is warmer use a 10W that is all that is needed to know right now.....some of this is not so easy to explain typing ... so that is as far as am going to go
good luck
Old Aug 16, 2002 | 07:08 AM
g_man80's Avatar
Yeah, I guess I was just reading too much into it. I get it now. It's really not worth loosing sleep over, haha.
Anyway, for the original question that was posted; you won't see any difference switching between such similar weight oils. Just like what was typed earlier.
Thanks,
G
Old Aug 16, 2002 | 07:28 AM
no difference....check what weather you will be using it in then decide colder 5W30 warmer 10W30
enjoy
Old Aug 16, 2002 | 05:09 PM
shawnhayes's Avatar
Oh my GOD, apparently I have to discuss the behavior of multiweight oil.
Ok, multiweight oil is what is called a "non-Newtonian fluid". In other words, viscosity INCREASES as temperature goes up (but this only applies for a limited range of temperatures - and automotive chemists aim for the -35 to 500 degree farhenheit range).
It takes tons and tons of egghead chemistry (that I used to know) to pull this trick, and is one of the major reasons you need to change your oil regularly (because the viscosity index improvers wear out over time).
So, at low temperatures, a 5W-30 oil has the same viscosity as a 5 weight straight oil at that temperature, and at engine operating temperature it has the same viscosity as a 30 weight straight oil.
Straight?
Shawn
Old Aug 16, 2002 | 06:06 PM
Ricey McRicerton's Avatar
hey shawnhaynes....you, my friend, are a genius
Hondog
Jun 5, 2004 07:29 PM
Almypal
Mar 10, 2004 12:43 PM
atermizi
Feb 18, 2004 12:37 PM
patdemps
May 9, 2003 11:00 AM
sayjdm
Nov 11, 2002 12:47 AM
