Difference in tenths and weight?
Old May 6, 2003 | 06:17 PM
patdemps's Avatar
Default Difference in tenths and weight?
Ok I have heard a few things:
For every tenth you gain (.1 or 1/10) then its a car length.....
For every 100 pounds its a tenth gain (.1 or 1/10).....
are those accurate?
Old May 6, 2003 | 08:01 PM
jlicrx's Avatar
Default Re: Difference in tenths and weight? (patdemps)
running in the 13 to 16 second range, the difference is about 10ft. - you can figure about 2 tenths for each 100 lbs. if you weigh between 1700 to 2300 lbs. - 3 tenths if you weigh between 1300 to 1700 lbs. - this assumes that once you take weight out, you can still get the same amount of traction - we dropped our car from 1700lbs with driver to 1610lbs and relocated some of the weight to the front and picked up 4 tenths without any other changes.
Old May 6, 2003 | 10:10 PM
DIRep972's Avatar
Smarter than you
Its kind of an inversly related relationship. The lighter the car is the more taking out wieght will make a difference. For instance taking 100lbs off a 2000lb car will make more of a difference then taking 100lbs off a 4000lb car. but also, the faster the car gets the harder it is to gain tenths in the 1/4. on a 16 sec car 10hp may gain u a tenth, but on a 9sec car 10hp might not make a slight difference.
but also judging car lengths is even harder. are u talking cars @ the finish line? 1/8 or 1/4? cars on the highway? it would be interesting to know though how many cars a tenth is @ the end of the track. that way at the street races you could guage pretty well if people were trying to hit u up for car length leads and all that.
Modified by DIRep at 11:33 PM 5/6/2003
Old May 6, 2003 | 10:59 PM
six sigma racing's Avatar
Default Re: Difference in tenths and weight? (DIRep)
speaking from my personal experience i went fro 1720 to 1620 with 220 hp i ran 11.6 to 11.4s.. then i drop the car weight even more to 1510 with with the same hp i war running 11.1 11.2
Old May 9, 2003 | 11:00 AM
patdemps's Avatar
Default Re: Difference in tenths and weight? (FTR11secALLMOTOR)
thanks for the posts. I under the relationship quite well now.....H-T
ketchup
Jul 28, 2004 10:58 AM
atermizi
Feb 18, 2004 12:37 PM
allmotorhonda
Jan 2, 2003 04:55 PM
SpecR_EK
Mar 16, 2002 02:33 AM
HX_Guy
Aug 15, 2001 03:21 PM
