finger control rant
Old Apr 22, 2009 | 08:52 PM
paulzy's Avatar
Default finger control rant
I don't know how you guys do it. I went from a foot control to a finger switch and I have to say it's like learning to weld all over again. Damn, I miss my foot pedal and miller
Old Apr 22, 2009 | 09:09 PM
9295EJ-t's Avatar
Default Re: finger control rant
best thing to do, set the cup on what you are welding, and tilt the tungsten away from the grounded metal.. start the arc, then slowly work the proper amount of heat into it, (until you get the proper size puddle) then go with it!
it wont take long to catch on...
it is definately conveniant when you start laying on your side to weld something cramped way to low to the ground, or super tight up behind something...
Old Apr 23, 2009 | 04:44 AM
downest's Avatar
I have used a finger control quite a bit, I'd rather drag my pedal under stuff with me or in tight spaces and use my knee or something. I have been shocked so many times with the thumbwheel and of course it doesn't default to off...
Old Apr 23, 2009 | 09:25 AM
Jasper_db1's Avatar
I can barely stick two pieces of metal together with the foot pedal and can't wait to set fire to something with the thumbwheel.
Old Apr 23, 2009 | 02:52 PM
ManBearPig4silly's Avatar
you get used to it. trying sticking your the point of your index finger into the corner the back cap and torch handle make and then use the slide with your thumb. Helps to steady the whole shibang.
Old Apr 23, 2009 | 09:05 PM
9295EJ-t's Avatar
when i use the thumb wheel, i hold the torch like a caveman would hold a spoon.... i use the side of my thumbs knuckle to handle the bizness!
RyanPm
Jun 20, 2009 05:28 AM
ruffrhyder
May 26, 2009 11:31 AM
gripek
Honda S2000
Mar 18, 2009 11:58 AM
Mikes1098
Welding / Fabrication
Jul 7, 2008 09:03 AM
ProjectCRXtacy
Feb 2, 2005 03:07 PM
