Honda S2000 Honda S2000
f22 bottom f20 top
Old Apr 22, 2009 | 02:54 PM
bresne61's Avatar
New User
Default f22 bottom f20 top
I recently hydro-locked my motor, and insurance is buying me a new one...I've found an excellent deal on an ap2 engine and transmission, and I want to use the head from my 2001 model. I would use the ap1 ecu, and get it tuned fairly soon.
1. I guess my question is: is it as simple as bolting the ap1 head on the ap2 block, and enjoy the extra torque gains?
2. What kind of power gains would I get?
I've searched and searched, but all I can find is hypothetical stuff...I hear people have done it, and I just wanted to make sure I wasn't getting in over my head if it required heavy modifications.
thanks a lot,
brent
Old Apr 22, 2009 | 03:26 PM
bresne61's Avatar
New User
Default Re: f22 bottom f20 top
the engine is out of an '08 model...I heard there was a difference in the harnesses
Old Apr 22, 2009 | 03:27 PM
bigmacnfries's Avatar
how did you hydrolock it?
Old Apr 22, 2009 | 03:35 PM
bresne61's Avatar
New User
sucked up water through intake, and it sent a rod through the oil pan...
Old Apr 22, 2009 | 05:32 PM
ouch - low intake? or very high water?
Old Apr 22, 2009 | 05:48 PM
bresne61's Avatar
New User
bit of both...
Old Apr 22, 2009 | 05:54 PM
MidwestAutoWorks's Avatar
heads are the same
Cams are different.
06 and up are DBW
so just use the whole ap2 motor and put the ap1 cams in.
Old Apr 22, 2009 | 05:59 PM
bresne61's Avatar
New User
DBW, sorry
So, use the wiring harness and everything from the '08?
thanks again
Old Apr 22, 2009 | 06:46 PM
Black S2K's Avatar
^ damn your gona run into a bit of a problem with dbw.
Old Apr 22, 2009 | 07:13 PM
bresne61's Avatar
New User
I don't know what dpw
Old Apr 22, 2009 | 07:18 PM
Toe_Knee's Avatar
Drive by wire - Pretty much the throttle cable is replaced by electrical wire and it's not mechanically controlled...I think that's one way to put it...
Old Apr 22, 2009 | 07:22 PM
bresne61's Avatar
New User
got it... I'm retarded with acronyms
Old Apr 22, 2009 | 07:59 PM
ysf..
Old Apr 22, 2009 | 09:02 PM
andre@raw's Avatar
Use the complete AP2 motor or do what u wanted to do AP2 short block with Ap2 head, you will have to change and use your original '01 harness and the AP1 intake manifold with all the sensors otherwise is the same.
grapevinecrx
Aug 10, 2007 09:33 AM
nexgen91
Mar 13, 2007 01:46 PM
boosted_dc2
Jun 11, 2004 03:09 PM
J2turbo21
Feb 25, 2003 05:12 PM
