will this work for assembly lube???
Old Jun 11, 2004 | 05:20 AM
boosted_dc2's Avatar
Default will this work for assembly lube???
this is all they had at my locl napa, im just using it for the cams, and other odds and end bearings etc.
thanks
Landon
Old Jun 11, 2004 | 05:29 AM
ykracing's Avatar
Default Re: will this work for assembly lube??? (boosted_dc2)
you might want to mix it with some standard oil...
Im not familiar with that product, so I would rather see you mix it like 50:50 with oil...
but thats my opinion...
Old Jun 11, 2004 | 06:23 AM
FOrSfEd's Avatar
Default Re: will this work for assembly lube??? (trboCIVICWRX)
Order the royal purple lube, it works really well.
Old Jun 11, 2004 | 06:28 AM
GSRswapandslow.
Guest
Posts: n/a
if you are using stock head bolts...ONLY use 10w30 on them when TQ'ing....if you're using ARP's ONLY use moly lube on them
other than that, that should work perfectly fine...you just have to remember to use the correct lube for the head bolts/studs
Old Jun 11, 2004 | 06:29 AM
Rod.'s Avatar
Default Re: will this work for assembly lube??? (FOrSfEd)
Do you have a o'reillys? That is where I got my assembly lube
Old Jun 11, 2004 | 06:30 AM
JDMCRX's Avatar
I usauly use oil additives such as STP its real thick and sticky. Used it on 4 motor build ups and when i first turn the motor up the pump primes fast.
Old Jun 11, 2004 | 08:34 AM
DonF's Avatar
Default Re: will this work for assembly lube??? (JDMCRX)
As Clevite is one of the largest plain bearing mfg. in the world, and makes that lube to be used as an assembly lube for eng. bearings, why do you think someone here would know more than Clevite?
Old Jun 11, 2004 | 09:20 AM
senpai's Avatar
foreal, don't Clevite make lots of bearings for domestics? Anyhow, looks cool to me, I used ***. lube from Autozone.
Old Jun 11, 2004 | 09:32 AM
275Performance's Avatar
Default Re: will this work for assembly lube??? (maztur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur &raquo;</TD></TR><TR><TD CLASS="quote">foreal, don't Clevite make lots of bearings for domestics? </TD></TR></TABLE>
I got some '79 Honda CVCC bearings and 2 CVCC pistons from Clevite, so they make some import stuff
Old Jun 11, 2004 | 11:27 AM
USDM 4G VTEC's Avatar
yes it will be fine with that
Old Jun 11, 2004 | 11:46 AM
JDMH22HATCH's Avatar
Default Re: (USDM 4G VTEC)
I've used it plenty in the past. You'll be fine
Old Jun 11, 2004 | 11:52 AM
Default Re: will this work for assembly lube??? (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">As Clevite is one of the largest plain bearing mfg. in the world, and makes that lube to be used as an assembly lube for eng. bearings, why do you think someone here would know more than Clevite?</TD></TR></TABLE>
well im sorry for asking, we all cant know everything like fine people like yourself. why the **** do you think im asking, cause i dont know ive never heard of clevite before in my life, so whatever.
thanks to all the people who actually helped me, and im not using it for head studs, just cam caps.
Landon
Old Jun 11, 2004 | 12:21 PM
CRX T-Si's Avatar
People now do not read what your asking.
That lube is good, it came with my ACL bearing kit.
Old Jun 11, 2004 | 12:45 PM
h22 civic's Avatar
moly
Old Jun 11, 2004 | 02:48 PM
Redwidow's Avatar
I used this stuff my mechanic gave me, very thick stays on them bearings good
just make sure your clevite lube its thick....You should be fine
Old Jun 11, 2004 | 03:09 PM
Armed Ferret's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur &raquo;</TD></TR><TR><TD CLASS="quote">I used ***. lube from Autozone.</TD></TR></TABLE>
sorry, but ya gotta admit...........it's funny
SHG_EasyE
10
Mar 22, 2007 01:12 PM
peakboosth22
Feb 13, 2007 08:02 PM
unknown2
Jun 13, 2004 08:56 PM
BIG RICH
Aug 15, 2003 04:33 PM
B18EG6
Apr 24, 2003 01:48 PM
