oil pan Gasket leaking
Old Aug 15, 2002 | 09:37 PM
slow90si's Avatar
Default oil pan Gasket leaking
I just recently put a te04h(lebaron) turbo on my sohc vtec motor. I took the car for a test drive to find that when i returned home that the oil pan gasket had a split in it around two of the bolts. One in front and one in back. My question is what extra precautions do you use when installing this gasket to make it not leak. Also what is the correct way to put the gasket on. I have read a few service manuals and they all bout say something differert.
do i put the gasket on the motor first or the pan.
do i put sealent on the whole gasket or just the corners.
do i put sealent on both sides of the gasket.
what is the best way to torque the bolts and how much per step
Please help
the darkside in waiting
Old Aug 15, 2002 | 10:01 PM
Flamenco-T's Avatar
Default Re: oil pan Gasket leaking (slow90si)
put the gasket in the pan then bolt it up on the block
seal the corner only
seal both sides of the gasket
torque them to approx 9 ft/lb in a criss cross pattern..
stan
Brembomaster
Engine Machining & Assembly
Jul 2, 2019 10:40 PM
george34
Nov 9, 2016 09:44 PM
jdmspoonitr
Nov 27, 2010 11:07 PM
DualCamDan
Jul 26, 2005 04:19 AM
keebler65
Oct 4, 2002 08:40 AM
