Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Vtec not kickin in on 05 ex after head gasket change.
Old Apr 22, 2009 | 01:49 PM
stealth_EK4's Avatar
Default Vtec not kickin in on 05 ex after head gasket change.
Hi im posting for a friend but anyways a friend just swapped out a head gasket on my freinds 05 civic EX. After the job the vtec is not kicking in when its supposed to and sometimes will not rev past 5000 rpm, btw the car is an automatic. Im going to take a look at is sometime soon. Any ideas on what to lo0k for maybe connectors in wrong places? everything at the vtec solenoid area looks to be connected last time I seen. the mechanic who did the work has been contacted but is lagging so I just wanna see if there is anything I can maybe look for.
Thanks
Old Apr 22, 2009 | 02:07 PM
toyomatt84's Avatar
Sanji
Default Re: Vetc not kickin in on 05 ex after head gasket change.
When do you think VTEC engages?
PS. If the car won't rev past 4,000 RPM's, the car is in "Limp" mode and needs to be serviced.
Old Apr 22, 2009 | 02:47 PM
Boilermaker1's Avatar
Some plugs look the same. Make sure everything is wired back to the right sensor. There's a couple identical plugs that can be messed up and cause an issue.
Old Apr 22, 2009 | 05:52 PM
Default Re: Vtec not kickin in on 05 ex after head gasket change.
im not sure when vtec engages on the em2 automaticits probably different then my b18c. Yea I will check the plugs i know on the b-series some plugs are identical and hook up to places they shouldn't. Ok thanx guys I will check the plugs and find out what that limp mode is all about.
thnx
Old Apr 22, 2009 | 06:20 PM
toyomatt84's Avatar
Sanji
thnx
It kicks in at 2700 rpm's. So, "hearing VTEC engagement" is a little more difficult than on other VTEC-equipped engines.
Old Apr 25, 2009 | 05:09 PM
waaBAAH's Avatar
i just recently seen this same issue on another civic that came to my shop.. complaints where vtec wasnt engaging.
after looking at the car the oil light was on as well with the car not going above 5k rpms. (starting bucking at that speed.)
turns out two connecters (customer just put in a used motor) were swapped. the oil pressure switch and the vtec solenoid. i swapped them around and toil light was off...car went faster then 5k rpms. even after i did the swapping of the two plugs i still couldnt "feel" vtec engaging.
the car was throwing a code for vtec malfunction....after swapping the vehcile didnt have this code anymore.
Old Apr 26, 2009 | 10:40 AM
UrPully's Avatar
if you can't find what's happening with all these kind people posting info
take it to a gear head
Crazyycivic98
Apr 13, 2015 05:01 PM
Luca
Sep 17, 2009 12:26 PM
waaBAAH
Jun 8, 2009 11:48 AM
eg6madness
Oct 10, 2007 11:05 PM
stickeyfingaz
Dec 29, 2004 10:19 AM
