safety on crome?
Old Apr 22, 2009 | 01:46 PM
hondaswap's Avatar
Default safety on crome?
i have a built h22a, tuned to 7 for break in but limiter at 8, im having trouble with power loss, i will get up to about 180km/h shift into fourth and my engine light will come on and the car will fall on its face like a fuel cut off, it doesnt do this all the time only the odd time, im just wondering what it could be, a safety on crome because its only tuned to 7 and i shift around 7 and half, or a throttle positioning sensor? once i turn the car off the light goes away and i have full power again. any ideas?
Old Apr 22, 2009 | 08:45 PM
mtber's Avatar
Default Re: safety on crome?
The issue you are having is not a "safety".
Does the check engine light come on & stay on ?
Old Apr 23, 2009 | 08:31 AM
hondaswap's Avatar
yes, until i turn the car off and turn it back on
Old Apr 23, 2009 | 09:35 AM
Relic1's Avatar
have you pulled the CEL?
My bet is something with the VTEC solenoid or oil pressure. (this is an ECU setting not an issue with your engine)
Old Apr 23, 2009 | 09:36 AM
mtber's Avatar
Check your malfunction indication code while the car is on with the engine running.
Instructions on how to do this are on http://www.phearable.net/tech
Old Apr 23, 2009 | 09:47 AM
hondaswap's Avatar
pulled the check engine light?
and im about to go check the MIL codes now, does the engine need to be running, or can i just turn the key ahead for power?
Old Apr 23, 2009 | 09:54 AM
mtber's Avatar
Check the codes while the vehicle is running
Old Apr 23, 2009 | 11:53 AM
hondaswap's Avatar
code 22, VTEC Oil Pressure Switch
Old Apr 23, 2009 | 12:04 PM
mtber's Avatar
Bypass the vtec pressure switch. Diagram on http://www.phearable.net/tech
Old Apr 23, 2009 | 12:26 PM
hondaswap's Avatar
ok, my vtec always kicks in, it doesnt kick in and out or anything, just to let you know
Old Apr 23, 2009 | 04:21 PM
mtber's Avatar
Does your motor have a vtec pressure switch ?
You need to resolve all malfunction indication lights to have a proper running vehicle.
Old Apr 23, 2009 | 09:25 PM
hondaswap's Avatar
no, once i bypass will it get rid of MIL code, and if i did test again i wouldnt get code 22?
i think when tuning it was disabled but another other guy tuned and enabled it.
Old Apr 24, 2009 | 06:53 AM
RC000E's Avatar
Yes, it can be disabled in Crome and must've been reenabled if the problem only happened post tune.
Old Apr 24, 2009 | 09:11 AM
hondaswap's Avatar
yeah, im trying to think back and im almost sure thats what happened, but im gonna do an oil pressure check, to be safe, then just bypass instead of driving 5 hours to get disabled on crome.
Old Apr 26, 2009 | 07:48 PM
hondaswap's Avatar
is bypassing that easy? just tap a4 and d6 together and your done, no unplugging of anything? no ungrounding any wires? no nothing?
Old Apr 27, 2009 | 02:00 PM
hondaswap's Avatar
anyone? as i would like to try this out asap!
Old Apr 27, 2009 | 02:27 PM
mtber's Avatar
Old Apr 28, 2009 | 12:31 AM
MONSTERek4's Avatar
well actually dont use crome to disable it for some reason it dont work just do the a4 to d6 is ur best bet for some reason when u use crom it get stuck on the vtec map
Old Apr 28, 2009 | 10:17 AM
hondaswap's Avatar
tried bypassing today, now throwing codes 21,22 any ideas?
BeansRSX
28
Jul 12, 2010 11:59 AM
oilspot
Feb 24, 2009 10:16 AM
xpoisnfreex
Dec 29, 2008 12:54 PM
Hatchback of Notre Dame
10
Mar 27, 2006 10:36 PM
TruePlayaz114
Nov 20, 2002 09:21 AM
